[SOLVED] Timing Violation after load added in Design Compiler report
coshy
Member level 4
Dear All.
I've been trying to study about Design Compiler.
And I've done report with SDC TCL as the below
but one Timing Problem encounters when I add "set_load [expr [load_of $lib_name/an02d0/A1] * 15] [all_outputs]"
I want to know how to resolve this problem in real field if they add load but it makes Violation of Timing?
set lib_name xxxxxx
current_design TOP
## Reset all constraints
reset_design
## Create clock object and set uncertainty
create_clock -period 2 [get_ports Clk]
set_clock_uncertainty 0.2 [get_clocks Clk]
## Set constraints on input ports
suppress_message UID-401
set_driving_cell -library $lib_name -lib_cell sdcfq1 [remove_from_collection [all_inputs] [get_ports Clk]]
set_input_delay 0.1 -max -clock Clk [remove_from_collection [all_inputs] [get_ports Clk]]
set_input_delay 1.2 -max -clock Clk [get_ports Neg_Flag]
## Set constraints on output ports
set_output_delay 1 -max -clock Clk [all_outputs]
then I 've got a report as the below
 Startpoint: Neg_Flag (input port clocked by Clk)
  Endpoint: I_COUNT/PCint_reg[2]
            (rising edge-triggered flip-flop clocked by Clk)
  Path Group: Clk
  Path Type: max
  Point                                    Incr       Path
  clock Clk (rise edge)                    0.00       0.00
  clock network delay (ideal)              0.00       0.00
  input external delay                     1.20       1.20 r
  Neg_Flag (in)                            0.06       1.26 r
  U157/ZN (nd02d1)                         0.12 *     1.38 f
  U164/ZN (nd02d2)                         0.09 *     1.47 r
  U180/ZN (invbd2)                         0.05 *     1.52 f
  U118/ZN (nd02d2)                         0.06 *     1.57 r
  U137/ZN (invbd4)                         0.06 *     1.64 f
  U88/ZN (nd02d1)                          0.04 *     1.68 r
  U178/ZN (nd03d0)                         0.10 *     1.78 f
  I_COUNT/PCint_reg[2]/D (dfnrq4)          0.00 *     1.78 f
  data arrival time                                   1.78
  clock Clk (rise edge)                    2.00       2.00
  clock network delay (ideal)              0.00       2.00
  clock uncertainty                       -0.20       1.80
  I_COUNT/PCint_reg[2]/CP (dfnrq4)         0.00       1.80 r
  library setup time                      -0.08       1.72
  data required time                                  1.72
  data arrival time                                  -1.78
  slack (VIOLATED)                                   -0.06
if I am reading this right, the violation is on a INPUT->FLOP path. load makes no difference in this scenario. input delay does.
When I check the timing without set_load [expr [load_of $lib_name/an02d0/A1] * 15] [all_outputs], there is no any violation issue.
But I add set_load [expr [load_of $lib_name/an02d0/A1] * 15] [all_outputs] then it makes the timing violation.
I I think set_load affects to output path timing. because if a big load added to output path, then output_delay value also corresponding to it. If I wrong, Please correct me.
And if input_delay causes the timing violation, then how to fix it in real field?
these sdc commands are about setting the environment to which your chip will interface to. I cannot tell you what is the right value for input_delay because I don't know your scenario. In a big chip design with lots of engineers, this is typically handled at top level by a senior engineer. In academic designs, these are typically ignored and only the clock frequency is set.
still, either way, your explanation of the load increase creating a violation doesn't make sense. load has no effect on the path you showed in your first post.
I think it makes sense. Because according to increase load value, previous F/F need to send more fast to meet the timing constraint so violation started in there.
this is my assuming.
there is no previous flip flop, your path is input->flop. output load does not apply to it, this path does not reach any output.
Yes You are right , this is the path what you said INPUT->FLOP. Let me check it again without set_load.
I can see the difference 0.06 -> 0.08 this makes the violation.
