how to create library for MAX232
suga
Member level 2
chennai
Hello frnds
Now am preparing schematic for that I need Max232 library .already I searched in library components in default(software).but it takes long time to search a library components so i want to create own library.please tell the steps for how to create max232 library
open the capture sch file.
(*) go to the file-new-library.
(*)right click the .olb file.
(*) select the new part.
(*)new part properties window will appear.
(*)fill the properties and give ok.
(*) Then draw your ic.
(*) add wherever you want in your circuit design.
@suga
Hello frnds
@chithublissly
How do you know in which program he try to do that ???? :shock:
each and every software must have that creation.
If any new part wants to create, creation of library it not there means what is the valid of the software????
Yes, but you give exact procedure, which is complete different between softwares. He didnt say which software!
Yes, but you give exact procedure, which is complete different between softwares. He didnt say which software![/
am using altium software
---------- Post added at 08:30 ---------- Previous post was at 08:27 ----------
thank for reply and am using altium software
  • Creating Library Components.PDF
thank u for reply
i had created library for max232.but i don't know how to add footprint.please tell the procedure
  • Module 16 - PCB Library Editor.pdf
thank u....after preparing a schematic what are all the procedure for prepare pcb
See this :
  • ENGG2800 - Altium Tutorial.pdf
  • Module 9 - Setting Up The PCB.pdf
  • TU0117 Getting Started with PCB Design.PDF
