Unknow Timing Arc in Innovus Post-Route Timing Report
Dedong
Newbie
This is no instance, no delay but just arrival and required time of the first timing arc in Innovus post-route timing report.
Could I ask where the arrival and required time come from?
Attached are the timing report and the applied sdc file generated from Genus.
Thanks!
  • sdc.txt
  • timing_full_clock.txt
Required = (clock period) - (external/internal delay) - (uncertainty)
Arrival = what you actually get when the path was timed
Slack = required - arrival
1250 period - 125 uncertainty - 375 output delay at the port is required time at the port.
= 750 ps
as for the arrival time, its the actual delays you see in your design (clk network. data path delays)
The bit i am not sure of - the phase shift number...
= 750 ps
phase shift = clock period in 99% of the cases.
exception #1: some portions of the design can have multi cycle paths, so you will see numbers that are N*period, with N in [1,2,3,...]
exeption #2: your design might have logic that operates on negedge and posedge, so phase shift will be clock_period/2.
LaTeX Commands Quick-Menu:
