[SOLVED] [MOVED] Need foot print of BQ24201 for Eagle library...!!
omega6
Member level 3
Sri Lanka
Hello Guys..!!
I don't know if this is the right place to post my question and sorry if im in the wrong place. I'm having some issues with creating the part BQ24201 in eagle library. Hope the genius guys here could help me by creating one for me if possible. I've attached the data sheet below for your reference.
Thanx...
  • bq24201.pdf
Re: Need foot print of BQ24201 for Eagle library...!!
Hai omega,
I cant get your question. r u creating lib or using that lib???
If you want to get cell_footprint
Search for the name in lib ex:- add2x
U can find that relevant foot print in lib file..
Ex:- cell_footprint : and2;
Also if u are soc encounter , Enter the command "reportFootPrint" It will display all foot prints for cells
u can also write it to a file using this command
syntax:- reportFootPrint -outfile filename
:razz:
Hi vijayR15,
I really cant understand what you are saying. The IC foot print for BQ24201 is not available in the Eagle library. So i'll have to create one in order to use the IC. I find it hard to create the foot print and hope someone can help me by creating one for me.
Thanx...
You will need to learn how to create new library parts. Search the web for Eagle tutorials - there are plenty out there.
Keith
Hi keith1200rs,
I've created custom parts in Eagle library before, But this time in having issues with this IC. That's why i'm asking you guys for help... :D
Thanx...
You haven't actually said what the problem is -
If you explained what the problem actually is then I am sure I can help.
Keith.
