Can you suggest backend tools?
pugongying
Member level 3
back end tool list
I can access synopsys backend tools,while it seems there are too much for me to learn,so can you suggest the tools used in the following backend flow?
a)logic Synthesis (design compiler)
b)floor plan(?)
c)clock tree synthesis(?)
d) Placement (?)
e) routing (?)
f) DRC&LVS(?)
thanks
blacksmith_vlsi
Newbie level 6
backend tools
b)floor plan(?)
d) Placement (?)
e) routing (?)
f) DRC&LVS(?)
thanks
a) synopsys design compiler
b) ~ f) Astro
spauls
Advanced Member level 2
back end tools
logic Synthesis (DC - Shell , RC Compiler , Blast RTL)
b)floor plan(SoC Encounter)
c)clock tree synthesis(Astro)
d) Placement (Soc Encounter, Blastfusion)
e) routing (Nanoroute)
f) DRC&LVS(Calibre)
dsairajkiran
Member level 3
india
best tools for backend
Hello,
a)Logic Synthesis (DC - Shell , RC Compiler , Blast RTL)
c)placement,timing,clock tree synthesis,optimization(FE)
e) Detail routing (Nanoroute)
f) DRC&LVS(Calibre,Assura,Hercules)
g)noise(Celtic)
h)power analysis(Vstrom)
rakesh1234
Member level 5
ic compiler soc encounter
g)noise(Celtic)
smith_kang
Member level 5
magma ic compiler soc encounter
For full Netlist to GDS you can use SoC Encounter. It has single solution from Netlist to GDS flow.
You have to use Caliber for LVS/DRC verification.
alcohol
Member level 1
earth
backend celtic
Anolog Layout cadence + diva for ( block fast )
cadence + assura
cadence + calibre for block & sing off
Laker + calibre
most tools can link Mentor calibre
how to choose need watch your fundry support good kit and rule file
if you have more time you can to do your self :D
pratap_v
Member level 4
logic synthesis backend
Hi
RTL compiler for logic synthesis
First Encounter for P&R
Assura or Calibre for Physical Verification
Celtic and Vstorm for Signal Integrity and Power Analysis
Timing Closure for PrimeTime
karthiktr
google suggest backend
Hi ,
If you can access all the synopsys tools please see the list below for the tool list :
a)logic Synthesis (Design Compiler)
b)floor plan (JupiterXT, for top-down as well as bottom up approach)
c)clock tree synthesis (Astro and IC Compiler)
d) Placement (Astro, Physical Compiler and IC Compiler)
e) routing (Astro and IC Compiler)
f) DRC&LVS (Hercules)
If you are a fresh starter with the synopsys backend tools I would suggest you to get used to OR start with IC Compiler which is the next generation tool for floorplan, CTS, placement and routing. Also, visit the www.synopsys.com and get yourself regestered into Solvnet --> a Google for chip designers.
Hope this helps.
Karthik
crazy_man
Member level 3
designing backend tools
b)floor plan - Jupiter XT
c)clock tree synthesis - Astro
d) Placement - Physical Compiler
e) routing Astro
f) DRC&LVS - Hercules
univer_solar
Member level 4
soc encounter ic compiler
I suggest you a tool that's good for BackEnd. It's Magma. You also do synthesize and STA and so on with this tool.
Good luck
vlsi_deepa
Newbie level 6
back end tools list
a)logic Synthesis -BlastCreate
b)floor plan - BlastFusion(Magma)
c)clock tree synthesis - BlastFusion
d) Placement - BlastFusion
e) routing - BlastFusion
edacrack
Member level 3
rtl-compiler icc
Good luck
Do you know how to use Magma? Send me a PM
eminem198123
Junior Member level 1
Beijing, China
can access be used as a backend
I suggest you to use SOC Encounter (Cadence)
or Blast Fusion (Magma), they are the next generation tools. For Astro and ICC (PC + Astro), I thinks it is still not strong enough.
shiv_emf
back end tools + calibre
Encounter is best i guess... u can do FULL flow on it !!
Virtuso layout editor n hercules for LVS n DRC
laglead
Full Member level 5
list of back end tools
synopsys design compiler is the most important.
pragya.laad
icc synthesis tool
ENCOUNTER is the best choice i feel. It has the full flow and you have to do DRC/LVS/antenna check using calibre but u can load those reports in encounter and can rectify the violations.
itsmeteja
Full Member level 2
Bangalore, India, India
backend tools top up
b)floor plan(ICC/magma)
c)clock tree synthesis(ICC/azuro/falcon-magma)
d) Placement (ICC/magma)
e) routing (ICC/magma)
f) DRC&LVS(k2 chameleon/hercules)
