netdeamon
Newbie level 6
I have a 8051 development board which contains AT89s52 chip.
I is programmed by a serial port.
Now the AT89s52 is programmed successfully but when I click on verify flash, it shows error.
Also I have to toggle the RESET/PROG button everytime. Like I click on read signature,it shows 0x1E 0x52 and afterwards when I click on say "ERASE CHIP" it will shows PROG ENABLE FAILED error.
Again I toggle RESET/PROG button and again after erasing the chip, if I select "write flash", the program will show "Prog Enable Failed" error.
I wanted to ask that can the AT89C2051 chip that is used to program the 8051 be defective? And if I replace the AT89C2051 with another new one , should I have to program the AT89C2051?
Do we need to program the AT89C2051?
