netdeamon
Newbie level 6
I got struck between these two links that show circuit for programming 89SXX.
1. In LINK 1 this link, the pin number 23,12,10,9,7,5,2 are used of DB 25 connector.
While in this link, pins 5,6,7,8,9,10,18 are used of DB 25 connector.
So which one of the DB 25 version is correct? Or both are correct?
2.The author has said that USB is used to supply 5 V, 100 mA current. But instead of cutting a USB cable and using it, can't we use a 5V source from a battery of 9 V?
3.I had some doubts about connection in this circuit , so I modified the circuit as follows.
Is the changes I made in circuit wrong?
![ISP-Flash Programmer.jpg ISP-Flash Programmer.jpg](https://www.edaboard.com/data/attachments/33/33630-97cb75fecf573dd87dd7c45dd8bf5b89.jpg)
4. Can I replace the 4 MHz clock with 11.0592 MHz in LINK 1.
