Wrong timing report from all path.
coshy
Member level 4
Dear All,
I'm trying to make a timing report for all path which is
1. Input to register path
2. Register to register path
3. Register to output path
4. Input to output path
Basically My design is
RTL:
module MY_DESIGN ( Cin1, Cin2, Cout, data1, data2, sel, clk, out1, out2, out3);
  input [4:0] Cin1, Cin2, data1, data2;
  input sel, clk;
  output [4:0] Cout, out1, out2, out3;
  reg   [4:0] R1, R2, R3, R4, out1, out2, out3;
  wire   [4:0] arth_o;
  ARITH U1_ARITH ( .a(data1), .b(data2), .sel(sel), .out1(arth_o) );
  COMBO U_COMBO ( .Cin1(Cin1), .Cin2(Cin2), .sel(sel), .Cout(Cout) );
always @ (posedge clk)
  begin
    R1 <= arth_o;
    R2 <= data1 & data2;
    R3 <= data1 + data2;
    R4 <= R2 + R3;
  end
always @ (out2, R1, R3, R4)
  begin
    out1 <= R1 + R3;
    out2 <= R3 & R4;
    out3 <= out2 - R3;
  end
endmodule
SDC
report_timing -from [all_inputs]               -to [all_registers -data_pins] -max_paths 10 > report_input2r.rpt
report_timing -from [all_registers -data_pins] -to [all_registers -data_pins] -max_paths 10 > report_reg2r.rpt
report_timing -from [all_registers -data_pins] -to [all_outputs]              -max_paths 10 > report_reg2o.rpt
report_timing -from [all_inputs]               -to [all_outputs]              -max_paths 10 > report_intput2out.rpt
And I've got the report report_reg2output but it seems something wrong.
Why can't report with any path? Did I something to do wrong?
Report : timing
        -path full
        -delay max
        -max_paths 10
Design : MY_DESIGN
Wire Load Model Mode: enclosed
No paths.
One thing is for input to output reports.
Report : timing
        -path full
        -delay max
        -max_paths 10
Design : MY_DESIGN
  Startpoint: sel (input port clocked by clk)
  Endpoint: Cout[4] (output port clocked by clk)
  Path Group: clk
  Path Type: max
  Point                                                   Incr       Path
  clock clk (rise edge)                                   0.00       0.00
  clock network delay (ideal)                             1.00       1.00
  data required time                                                 3.75
  data arrival time                                                 -1.40
  slack (MET)                                                        2.35
As you can see the above report, It supposed to report with Cin1[4:0] and Cin2[4:0] to Cout[4:0] path not only sel to Cout[4:0] path. But didn't it.
Would you please help me how to get a path timing Right report ?
try report_timing -from [all_registers], without the data pin option and see what you get
Maybe I did something wrong.
Sir, I've got
report_input2r.rpt
Warning: cell 'R1_reg[0]' is of the wrong type. (UID-119)
Warning: cell 'R1_reg[1]' is of the wrong type. (UID-119)
Warning: cell 'R1_reg[2]' is of the wrong type. (UID-119)
Warning: cell 'R1_reg[3]' is of the wrong type. (UID-119)
Warning: cell 'R1_reg[4]' is of the wrong type. (UID-119)
Warning: cell 'R3_reg[0]' is of the wrong type. (UID-119)
Warning: cell 'R3_reg[1]' is of the wrong type. (UID-119)
Warning: cell 'R3_reg[2]' is of the wrong type. (UID-119)
Warning: cell 'R3_reg[3]' is of the wrong type. (UID-119)
Warning: cell 'R3_reg[4]' is of the wrong type. (UID-119)
Warning: ...10 additional objects are of the wrong type. (UID-119)
Warning: Ignoring all 20 objects in collection '_sel675' because they are not of type pin, port, net, clock, or generated_clock. (UID-445)
Error: Value for list '-to' must have 1 elements. (CMD-036)
report_reg2r.rpt
Warning: Ignoring all 20 objects in collection '_sel676' because they are not of type pin, port, net, clock, or generated_clock. (UID-445)
Error: Value for list '-from' must have 1 elements. (CMD-036)
Warning: Ignoring all 20 objects in collection '_sel677' because they are not of type pin, port, net, clock, or generated_clock. (UID-445)
report_reg2o.rpt
Warning: Ignoring all 20 objects in collection '_sel678' because they are not of type pin, port, net, clock, or generated_clock. (UID-445)
Information: Changed wire load model for 'DW01_add_width5' from '(none)' to 'ForQA'. (OPT-170)
Information: Changed wire load model for '*ADD_UNS_OP_5_5_5' from '(none)' to 'ForQA'. (OPT-170)
Information: Changed wire load model for 'DW01_sub_width5' from '(none)' to 'ForQA'. (OPT-170)
Information: Changed wire load model for '*SUB_UNS_OP_5_5_5' from '(none)' to 'ForQA'. (OPT-170)
Information: Updating design information... (UID-85)
Report : timing
        -path full
        -delay max
        -max_paths 10
Design : MY_DESIGN
  Endpoint: Cout[0] (output port clocked by clk)
  Path Group: clk
  Path Type: max
  Des/Clust/Port     Wire Load Model       Library
  MY_DESIGN          ForQA                 cbmax
  ARITH              ForQA                 cbmax
  COMBO              ForQA                 cbmax
  Point                                                   Incr       Path
  input external delay                                    0.40       1.40 f
  sel (in)                                                0.00       1.40 f
  U_COMBO/sel (COMBO)                                     0.00       1.40 f
  U_COMBO/U2_ARITH/sel (ARITH)                            0.00       1.40 f
  U_COMBO/U2_ARITH/I_0/Z (GTECH_NOT)                      0.00       1.40 r
  U_COMBO/U2_ARITH/B_0/Z (GTECH_BUF)                      0.00       1.40 r
  U_COMBO/U2_ARITH/C15/Z_0 (*SELECT_OP_2.5_2.1_5)         0.00       1.40 r
  U_COMBO/U2_ARITH/out1[0] (ARITH)                        0.00       1.40 r
  U_COMBO/add_68/A_0 (*ADD_UNS_OP_5_5_5)                  0.00       1.40 r
  U_COMBO/add_68/*cell*62/A[0] (DW01_add_width5)          0.00       1.40 r
  U_COMBO/add_68/*cell*62/SUM[0] (DW01_add_width5)        0.00       1.40 r
  U_COMBO/add_68/Z_0 (*ADD_UNS_OP_5_5_5)                  0.00       1.40 r
  U_COMBO/Cout[0] (COMBO)                                 0.00       1.40 r
  Cout[0] (out)                                           0.00       1.40 r
  data arrival time                                                  1.40
  clock clk (rise edge)                                   3.00       3.00
  clock network delay (ideal)                             1.00       4.00
  clock uncertainty                                      -0.15       3.85
  output external delay                                  -0.10       3.75
  slack (MET)                                                        2.35
When I used as the below,
report_timing -from [all_inputs]     -to [all_registers ] -max_paths 10 > report_input2r.rpt
report_timing -from [all_registers ] -to [all_registers ] -max_paths 10 > report_reg2r.rpt
report_timing -from [all_registers ] -to [all_outputs]    -max_paths 10 > report_reg2o.rpt
