AmmarAli
Junior Member level 1
Hi
I am working on wide band antenna 4 element array ( 2.4-6GHz) and need to equally divide power between antenna element. I desired to use Wilkinson power divider as I have seen in previous work that it has good characteristic in wide band application. I desired to use the circular configuration to minimize the PCB side.
I could not fine references illustrate the equation of the circular configuration. I will be very thankful if anyone can guide me for good reference to get better understanding.
Thanks
Ammar
Thanks
Ammar
