varma_cs012 said:check the script one more time. You may be given the code incorrect.
rahultcd said:As per my understanding , u have created pcell using skill, & now u r not able to see its parameter/property.
In this case instatiate this pcell in some other layout view , & then chek its property , u may be able to see parameters set by u ..
rahultcd said:then , 1st of all are u able to instantite ? & is ur pcell got created successfully? .. & how u r checkig its property/parameters ?
rahultcd said:ok so if it is generating pcell then , wht it is showing when u chk property(by pressing "Q" key).?
