Feb 27, 2008 #1 Q qhyfish Newbie level 5 Joined Feb 27, 2008 Messages 9 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,325 i loaded a "pcell.il" from CDS_INSTALL/..sample../pcell.il , then created layout , but there is no parameter . what need I do more ?
Feb 28, 2008 #2 V varma_cs012 Member level 5 Joined Jan 22, 2008 Messages 89 Helped 9 Reputation 18 Reaction score 2 Trophy points 1,288 Location Hyderabad Activity points 1,853 Re: Why not layout without parameter after load " check the script one more time. You may be given the code incorrect.
Feb 28, 2008 #3 Q qhyfish Newbie level 5 Joined Feb 27, 2008 Messages 9 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,325 Re: Why not layout without parameter after load " varma_cs012 said: check the script one more time. You may be given the code incorrect. Click to expand... But this file from Tools Path . here it attached , Please help me check it Thanks and Regards qhyfish
Feb 28, 2008 #4 R rahultcd Member level 1 Joined Nov 29, 2006 Messages 37 Helped 0 Reputation 0 Reaction score 1 Trophy points 1,286 Activity points 1,491 Re: Why not layout without parameter after load " As per my understanding , u have created pcell using skill, & now u r not able to see its parameter/property. In this case instatiate this pcell in some other layout view , & then chek its property , u may be able to see parameters set by u ..
Feb 28, 2008 #5 Q qhyfish Newbie level 5 Joined Feb 27, 2008 Messages 9 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,325 Re: Why not layout without parameter after load " rahultcd said: As per my understanding , u have created pcell using skill, & now u r not able to see its parameter/property. In this case instatiate this pcell in some other layout view , & then chek its property , u may be able to see parameters set by u .. Click to expand... Thank you for replay , But when I instatiate this pcell , there is no parameters . Regards gray
Feb 28, 2008 #6 R rahultcd Member level 1 Joined Nov 29, 2006 Messages 37 Helped 0 Reputation 0 Reaction score 1 Trophy points 1,286 Activity points 1,491 then , 1st of all are u able to instantite ? & is ur pcell got created successfully? .. & how u r checkig its property/parameters ?
Feb 28, 2008 #7 Q qhyfish Newbie level 5 Joined Feb 27, 2008 Messages 9 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,325 Re: Why not layout without parameter after load " rahultcd said: then , 1st of all are u able to instantite ? & is ur pcell got created successfully? .. & how u r checkig its property/parameters ? Click to expand... following is log : \i load "pcell.il" \o Generating Pcell for 'mypcell_test layout'. \t t \a leCreateInstForm->cellName->value = "mypcell_test" \r "mypcell_test" \a ddsSyncWithForm(hiGetCurrentForm() 'browse 'libName 'cellName 'viewName) \r t so ...
Feb 28, 2008 #8 R rahultcd Member level 1 Joined Nov 29, 2006 Messages 37 Helped 0 Reputation 0 Reaction score 1 Trophy points 1,286 Activity points 1,491 ok so if it is generating pcell then , wht it is showing when u chk property(by pressing "Q" key).?
Feb 28, 2008 #9 Q qhyfish Newbie level 5 Joined Feb 27, 2008 Messages 9 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,325 Re: Why not layout without parameter after load " rahultcd said: ok so if it is generating pcell then , wht it is showing when u chk property(by pressing "Q" key).? Click to expand... parameter button is grey
