I have few points,
1. Leakage : Since memory is a charge storing element.
2. Speed : How fast read/write operations are done. How many clock cycles does it requires to complete one read/write operation.
3. During layout how much area does it take (depending on size of memory)
The static memory are composed of bit cell-block , address decoder block and sense amplifier block and read/write io block . The constraint on the memory are timing / power/ area . So as a designer your job is to achieve the goal under those constraints with different architecture and circuits .
Thanks Dinesh and Nobody.
The answers are really helpful.
Dinesh.....
I had replied the same as what you said for layout since I am layout design engineer, but was not so sure of it.
I thought he was looking for some more points.
