Want to know operation of this Schematic
1) What your suggestion on Post #34 circuit? As per that circuit both relay should connect at the same time it connects in alternate way, like one is ON and other is OFF, i am interested to understand logic of this circuit
You can drive the second relay by inverting the signal to the first relay.
You showed progress by drawing your own schematic. I suggest you continue working on that.
Also, there are relays known as double-pole double-throw type (DPDT). These have two separate sets of contacts which would allow you to do what you want, all in one housing.
2) Post 39 Falstad circuit really helps me to understand the operation of the circuit, but that circuit operates on 400 ohms coil resistance of relay, but in my case i am using T7CS5D-24 relay parts from Tyco, its having 1600 ohms coil resistance, what type of modification i have to do to drive this Tyco relay? One limitation is i can not increase the power supply from 24VDC
I used 400 ohms only as a guess.
Since yours is 1600 ohms then it is likely to work on the 21 or 22 V coming from the charge-pump supply.
You should test it to find out what is the minimum voltage that will activate it.
3) Can you suggest me any Op-amp part number which is low cost and perform the operation, what we are looking for in Post #34 circuit.
The op amps can be general purpose. You need to use a type that can withstand 24 V at its pins. The all-purpose 741 may suit.
You have to comply with the specs. For instance, the inputs are not supposed to be exposed to a differential of greater than +5V or -5V. This may or may not occur in your project.
4) This 'Full-wave Rectifier with Smoothing Capacitor' circuit is efficient to generate smooth 24VDC (i mean pure 24VDC)? do you know any such compaq part which perform this action?
This power supply is practically the most popular type on the planet. It is reliable and easy to make, even for beginners.
Compaq may make such a supply however I'm not familiar with Compaq parts lists.
1) Thanks for appreciation, yes i would like to operate the second relay by inverting the signal of first relay in Post #34 circuit, actually i tried diffrent configuartion by modifying the circuit but i am unable to do that, could you please modify Post # 34 on falstad and post a new falstad link? In case application i dont require 2 contacts thats why i have finalized SPST relay
2) In Post 39 i have tried to change capacitor value to drive 1600 ohms coil of relay, but eventhough i am incresing the value above 300uf, relay should not operate, could you modify that Post#39 circuit for 1600 Ohms relay? (My relay specs are Rated voltage 24VDC, operate voltage 18VDC, release voltage 1.2VDC, coil resistance 1600 ohms 10% tolerence, rated coil power 360mW
3) Withstand voltage means supply voltage of op amp? can you elaborate more on this " For instance, the inputs are not supposed to be exposed to a differential of greater than +5V or -5V. This may or may not occur in your project."
4) Actually i am more interested to impant readymade 24AC to 24VDC power supply module, if i will get it in low cost
5) On Post#39 circuit, i found that first op amp works on 28VDC and second op amp work on +- 15VDC, i am unable to understand reason why you did that? because i think both op amp are operate as voltage comparator mode right? and one more thing cant we operate both op amp on 24VDC only, if its possible what are the necessary changes require in Post#39 ciruit? why i am asking this because if both op amps operates on diffrent voltages then i have put extra circuit for that voltages for 28VDC and +-15VDC, it increase the board size and cost of the circuit, let me know your thoughts on this.
I do not know of any way to turn off a SPST relay by energizing the coil.
I get the impression that your second relay is supposed to be on when there is no power going to it. This does not happen with a SPST relay.
You may have to consider using a double-throw relay. Use the normally closed contacts if that is what you need.
My simulation works when the capacitors are under 100 uF. Notice the charge does not vary more than a fraction of a volt. That is adequate in this case.
Seeing 5 in my book was a misread of small print by me. It is +15 or -15V when supply V is at the maximum recommended + and -30V. (I have often fed an op amp input volt levels which had more than 5V difference without a problem, but I also have not often powered an op amp from greater than 15V, and I have not often used a bipolar supply.)
The important spec is that the input volt levels should not exceed supply rails at either polarity.
This is where you will have to experiment. It is a vital stage in developing a project like this.
Your success in the electronics field requires that you discover what are the limits of the components you build with.
In other words, it's better if components go bad in the lab, rather than in someone's home.
And you must experiment and learn by your own initiative. There won't always be someone to help you in a tight spot.
Both op amps can operate from a single supply in this application.
I forgot to edit specs on one of them. I have now updated the specs so both produce between 2V and almost supply_V+. This approximately describes a 741 type.
Following is the latest revision containing two op amps. Copy and paste it into the Import window of the Falstad simulator.
Code Javascript - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
$ 1 5.0E-6 1.0312258501325766 50 5.0 50
c 368 64 368 112 0 6.8E-5 1.2981832455793487
c 368 368 368 416 0 6.8E-5 1.3450823077025862
d 368 240 368 112 1 0.805904783
d 368 368 368 240 1 0.805904783
w 368 240 288 240 0
t 240 144 288 144 0 -1 -0.6427586446993736 -0.6722361988267274 100.0
t 240 336 288 336 0 1 -23.411956093611852 0.5585663522607924 100.0
w 288 160 288 240 0
w 288 240 288 320 0
w 288 64 288 128 0
w 288 352 288 416 0
z 240 240 240 144 1 0.805904783 16.0
z 240 336 240 240 1 0.805904783 16.0
R 48 128 48 64 1 2 1000.0 2.5 2.5 0.0 0.5
R 112 32 64 32 0 0 40.0 24.0 0.0 0.0 0.5
g 176 448 176 480 0
w 560 112 560 144 0
w 608 368 672 368 0
r 192 240 240 240 0 680.0
s 48 128 48 224 0 0 false
178 624 112 704 112 0 1 0.2 0.013323261892692211 0.05 1000000.0 0.013000000000000001 1600.0
w 672 368 672 320 0
w 176 448 288 448 0
w 112 32 288 32 0
r 48 224 112 224 0 2200.0
d 624 160 560 160 1 0.805904783
w 560 144 624 144 0
a 528 240 608 240 0 19.0 2.0 1000000.0
r 512 160 512 224 0 3300.0
z 560 368 560 288 1 0.805904783 16.0
r 464 160 464 256 0 3300.0
r 464 256 464 368 0 22000.0
w 464 256 528 256 0
w 512 224 528 224 0
r 416 112 416 160 0 330.0
c 416 160 416 368 0 2.2E-5 20.616262551244468
w 368 368 416 368 0
w 368 112 416 112 0
w 416 160 464 160 0
w 416 368 464 368 2
w 464 368 512 368 0
w 512 368 560 368 0
w 464 160 512 160 0
r 608 240 608 304 0 4700.0
r 608 304 608 368 0 10000.0
t 608 304 672 304 0 1 0.6222519009431142 0.6505044793208938 100.0
w 560 368 608 368 0
w 624 208 624 160 0
w 560 144 560 160 0
w 416 112 560 112 2
d 288 64 368 64 1 0.805904783
d 368 416 288 416 1 0.805904783
r 288 32 368 32 0 33.0
w 368 32 368 64 0
w 288 32 288 64 0
r 288 448 368 448 0 33.0
w 368 416 368 448 0
w 288 416 288 448 0
a 112 240 192 240 0 23.0 2.0 1000000.0
r 112 256 112 448 0 3300.0
w 112 448 176 448 0
r 112 256 112 32 0 22000.0
r 48 224 48 448 0 10000.0
w 48 448 112 448 0
w 624 208 672 208 0
w 672 208 672 288 0
r 512 288 512 368 0 22000.0
w 512 224 512 288 0
w 512 288 560 288 0
o 0 16 0 35 1.961913824518935 0.039238276490378705 0 -1
o 1 16 0 35 5.126167610322753 0.05126167610322754 1 -1
o 43 32 0 35 18.707220957835556 0.005846006549323612 2 -1
1) actually earlier you said that this second relay might operate as in inverting mode in Post #34 circuit, can you make the necessary changes in this circuit if we want to operate both this relay invertly.
2) yes i have import this java script and checked it, it is working well
3 ) you mean to say i have to order a op amps which should operate on 0 to 24VDC right? what are the other factors i have to concern? yes you are right i need to find out the limit of each components, that is why i am planning to test this circuit first on general purpose board and after that i will move forward to proto type stage
4) Yes i tried to operate both op amps by changing the voltage level
5) one more question, can you design some logic circuit in falstad for CLK pulse input of op amp? actually i thoguht its better if we can take multiple input from diffrent port of microcontroller (for example 3 diffrent port of microcontroller) if all 3 input logic is fullfill then only this logic circuit would generate pulse (5VDC, 1KHz, 50% duty cycle), by doing that we can move forward to next level of redundant design, let me know your thoughts on this
The falstad simulator code below shows how a relay can be made to shut off when a high signal comes from the left.
An optocoupler will convey a signal, yet nothing is directly connected to the charge pump circuitry.
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
$ 1 5.0E-6 2.688763906446752 52 5.0 50
R 432 80 432 32 0 0 40.0 24.0 0.0 0.0 0.5
178 560 48 656 48 0 1 0.2 0.014976359909738737 0.05 1000000.0 0.013000000000000001 1600.0
t 432 240 512 240 0 1 0.6120231621508205 0.6498473065688067 100.0
g 512 320 512 368 0
w 512 192 512 224 0
w 512 256 512 320 0
d 512 192 512 80 1 0.805904783
w 80 320 256 320 0
w 304 320 512 320 0
162 256 240 256 320 1 2.1024259 1.0 0.0 0.0
w 560 96 560 192 0
w 512 192 560 192 0
w 512 80 560 80 0
r 432 80 432 240 0 10000.0
w 432 80 512 80 0
s 304 240 304 320 0 1 false
r 432 240 304 240 0 100.0
x 32 179 179 185 0 24 when charge
x 209 353 350 359 0 24 optocoupler
r 80 240 256 240 0 1200.0
x 21 144 183 150 0 24 21V incoming
x 39 211 171 217 0 24 pump is on
v 80 320 80 240 0 2 40.0 11.0 11.0 0.0 0.5
x 104 413 471 419 0 24 you close switch while led is on
x 41 75 169 81 0 24 this source
x 41 109 163 115 0 24 represents
x 89 384 486 390 0 24 switch represents a photodetector
Seeing that you took on this project I supposed you had a number of op amps on hand. Especially the 741 type because it is popular and inexpensive. It should work in this project.
The main thing to watch is that your device can withstand whatever volt level it will be subjected to. This includes spikes and surges on the supply lines.
That's good.
Did you also test your 24V relay to make sure what volt level it will close at? And what volt level it will open at?
The simulation's clock signal represents 5V pulses continually coming from your microcontroller. The switch represents whether the pulse train is on or off. There is no need for circuitry in between.
The frequency is 1 kHz only because I chose it out of the air. It is a convenient value to use in the simulator. However you should experiment with a range from 2 to 20,000 Hz.
Frequencies above 16 kHz are often preferred because that is higher than humans can hear. It is less likely to create audible buzzing noises.
The capacitors can be adjusted to suit. Their values should be increased if you use lower than 300 Hz.
In post#39 I'm interested to opearate my relay from 22V to 26V, because I have read from UL document and we should consider such amount of tolerance in this circuit, can you update the post 39 falstad circuit for this voltage range? Because I tried this current circuit but it's not operate more then +- 0.5 tolerance
I prefer to use the post #43 version because that has the correct ohm value for your relay coil. It is my latest update.
It appears to work okay on a 26V supply, without any changes. The zener values will still work okay.
If you wish, you can edit the op amp maximum output spec. Observe what is the volt level of its positive supply rail while the simulation is running. Then edit the max output spec to match that.
By mistake I wrote post 39 but I was talking about post 43 only, I tried to changes different supply but that circuit works on 2 percent positive tolerance but itsnot working on 2 percent negative tolerance, more precisely I'm interested to operate this circuit from 24vdc to 26 vdc supply voltage, and I'm sure it needs some alteration in post 43 circuit, can you make it necessary changes on post 43 circuit.
I changed supply voltage by pressing ctrl key, and clicking the '+24' at upper left.
I'm using a Macintosh. It may be the alt key on a PC.
I entered 26 in the box labelled voltage.
This required changing the maximum output levels of the op amps.
Here is the update:
Code Java(TM) 2 Platform Standard Edition 5.0 - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
$ 1 5.0E-6 0.9487735836358526 50 5.0 50
c 400 80 400 128 0 6.8E-5 1.6132872599683417
c 400 384 400 432 0 6.8E-5 1.6787836982203772
d 400 256 400 128 1 0.805904783
d 400 384 400 256 1 0.805904783
w 400 256 320 256 0
t 272 160 320 160 0 -1 -0.6508863898936319 -0.6765884450086084 100.0
t 272 352 320 352 0 1 -25.41573159262423 0.5585663522607927 100.0
w 320 176 320 256 0
w 320 256 320 336 0
w 320 80 320 144 0
w 320 368 320 432 0
z 272 256 272 160 1 0.805904783 16.0
z 272 352 272 256 1 0.805904783 16.0
R 80 144 80 80 1 2 1000.0 2.5 2.5 0.0 0.5
R 144 48 96 48 0 0 40.0 26.0 0.0 0.0 0.5
g 208 464 208 496 0
w 592 128 592 160 0
w 640 384 704 384 0
r 224 256 272 256 0 680.0
s 80 144 80 240 0 0 false
178 656 128 736 128 0 1 0.2 0.014331109653582268 0.05 1000000.0 0.013000000000000001 1600.0
w 704 384 704 336 0
w 208 464 320 464 0
w 144 48 320 48 0
r 80 240 144 240 0 2200.0
d 656 176 592 176 1 0.805904783
w 592 160 656 160 0
a 560 256 640 256 0 23.0 2.0 1000000.0
r 544 176 544 240 0 3300.0
z 592 384 592 304 1 0.805904783 16.0
r 496 176 496 272 0 3300.0
r 496 272 496 384 0 22000.0
w 496 272 560 272 0
w 544 240 560 240 0
r 448 128 448 176 0 330.0
c 448 176 448 384 0 2.2E-5 22.029779835343014
w 400 384 448 384 0
w 400 128 448 128 0
w 448 176 496 176 0
w 448 384 496 384 2
w 496 384 544 384 0
w 544 384 592 384 0
w 496 176 544 176 0
r 640 256 640 320 0 4700.0
r 640 320 640 384 0 10000.0
t 640 320 704 320 0 1 0.627410450292603 0.6534652960166119 100.0
w 592 384 640 384 0
w 656 224 656 176 0
w 592 160 592 176 0
w 448 128 592 128 2
d 320 80 400 80 1 0.805904783
d 400 432 320 432 1 0.805904783
r 320 48 400 48 0 47.0
w 400 48 400 80 0
w 320 48 320 80 0
r 320 464 400 464 0 47.0
w 400 432 400 464 0
w 320 432 320 464 0
a 144 256 224 256 0 26.0 2.0 1000000.0
r 144 272 144 464 0 3300.0
w 144 464 208 464 0
r 144 272 144 48 0 22000.0
r 80 240 80 464 0 10000.0
w 80 464 144 464 0
w 656 224 704 224 0
w 704 224 704 304 0
r 544 304 544 384 0 22000.0
w 544 240 544 304 0
w 544 304 592 304 0
o 0 16 0 35 15.69531059615148 0.15695310596151482 0 -1
o 1 16 0 35 2.5630838051613765 0.05126167610322754 1 -1
o 43 32 0 35 37.41444191567111 0.005846006549323612 2 -1
Yes i have observe and simulate the circuit on falstad simulator, now post #49 circuit operates with +- 2V tolerence which is good as per my desire.
i have one question with post # 49 circuit, you have changed the op amp voltage also, now first op amp is operates on Min 2 to Max 26V, and second op amp operates on Min 2 to Max 23 V, those supply voltage is mandatory to get +- 2VDC tolerence? because i have changed the op amp voltage and make it Min 0 to Max 24VDC, eventhough circuit is operates from 24VDC to 26VDC and i am getting +-2VDC tolerence, as per my requirement. is it okay if i operates in this manner?
actually as i said earlier i have operates all the compoent on 24VDC only but i need tolerence of +- 2VDC means circuit should operate from 24VDC to 26VDC.
i am going to procure the component to test this circuit on general purpose board(so this component is leaded only) if all is going well in this circuit i move forward to prototype stage, please find the attached BOM with new falstad script with naming, and let me know your inputs regarding specs
  • Charge pump BOM.pdf
  • Falstad script.txt
An op amp typically can output close to its supply V. Whether it is 24V or 26V. For completeness it's wise to enter it in the spec table, after changing the supply V.
Component values are not critical. 10 percent tolerance is adequate and could be less expene than 1% components you have chosen. It's up to you.
When the clock input is shut off, C1 will start acquiring a greater charge. It may reach supply V. You selected a 6.3V rating. It needs to be rated higher than the supply V.
The transistors T1 & T2 are a question mark. They need to turn on sufficiently so that ample current will flow. You selected small-signal NPN and PNP in your parts list BOM. There's a chance these will overheat in use. They will carry surge current when the clock input turns on.
Whatever devices you use must be rated to withstand 26V (or whatever is the highest anticipated V).
You may end up needing medium power transistors.
1) the Op amp i have chosen is sufficient to perform in our application, you have not comment on the op amp what i have chosen in BOM.
2) Yes i will end up with 10% tolerence of the passive components, but for the prior testing i think lets go in to safer side, this component is only for testing of the circuit preactically.
3) yes you are right but i have selected two types of capacitors because i was not sure which one will give us optimum result, Electrolytic capacitor is okay ? have a look on BOM i have selected electrolytic capacitor also
4) check this part now i have selected T2,T4=BC817-16E6327 and T1= FMMT549, is it okay?
5) yes i tried to keep withstand voltage around 26V
If you have any other comment most welcome
For op amps, I would start out using the least expensive ones. This application does not need a fast slew rate, nor low impedance output.
So it's puzzling why you chose op amps that cost $1.96 each.
Electrolytics are okay. The charge on the capacitors is always the same polarity.
R6 (680 ohms) is currently letting through 10 mA, in order to turn the transistors full on in the simulation. However this is probably too much bias current for real transistors. R6 should be increased to 2200.
You should obtain one or more sets of transistors, to experiment with as you develop a prototype. Why not try small signal type first, since it's just possible they will be sufficient? Obtain the medium power type as well, just in case.
Expect to burn up a few components as you get experience.
You should have an assortment of resistors and capacitors. As come in kits of 100 or more. Less expense than buying piecemeal.
These are things one is likely have on hand after getting some experience with simpler projects, before attempting something where people's lives are at stake.
LM358N op amp is okay as per specification please have a look on that, its very cheap.
Then i would freeze those elctrolytic capacitor as per my BOM, but could you please the polarity position as per our circuit?
I am replacing R6 from 680 Ohms to 2200 Ohms.
Yes i am planning to buy extra quantity, we have to consider falsare rate also.
Yes for production we generally purchase 10000 qty but as of now for this test purpose i am gonna buy lesser quantity even if this circuit will give good result then i am gonna move forward to prototype stage and in that i am gonna use SMT component.
LM358 appears satisfactory.
It can handle 26V supply.
It can output more than 10mA
It can both source and sink current.
There is a question whether the right-hand op amp should be powered (a) from the charge-pump, or (b) from the 26V supply.
Method A draws from the right-hand power loop only, independent from the left-hand power loop. This may be desirable. However it requires that you use two separate op amp chips, and that is more expense.
Method B seems as though it should work.
It is wise to experiment with all options to make sure.
The capacitors all have negative terminal toward supply ground.
No LM358 handle 32V supply, have a look on this https://www.fairchildsemi.com/ds/LM/LM358.pdf
Yes you are right i will try both options.
And i have just simulate the Post#49 circuit but its operates on 24VDC to 26VDC, but as per UL you need to have tolerence about 2V, means circuit should operates from 22VDC to 26VDC, please make the necessary change in Post # 49 circuit.
By mistake i wrote 24VDC to 26VDC. please make the necessary change in the Post#49 circuit so it can operates from 22VDC to 26VDC supply.
Yes, LM358 can handle up to 32V.
If the supply is reduced to 22V, then that means the relay gets 18 or 19V.
Since the relay is rated for 24V, it's possible the relay will not activate.
You can examine this yourself by changing the supply V at upper left (in the simulation).
Therefore to comply with UL specs, you must either:
(a) change to a 18 or 20 V relay, or
(b) change to a 28 V power supply, or
(c) be lucky enough to have a 24V relay that activates down to 19 V.
Yes you are right but the relay which i have select operating voltage of that relay is 18VDC so i guess relay is not an issue and it has to operate from 22V DC, let me know your thoughts on this.
So do we need to make any necessary changes if we want to operate relay from 22VDC to 26VDC? kindly post the updated version of Post#49 circuit
My relay datasheet is https://www.te.com/catalog/pn/en/2-1393190-8
Do let me know if you require any other information regarding relay.
The relay is rated 360 mW.
24V
1600 ohms
At 24 V, it results in 15 mA activation current.
There is a good chance it will not operate in your project, if you apply 22V supply at the left.
so any other soulution how we can operate the circuit from 22VDC to 26VDC because its basic requirement from UL.
Is it possible to design a circuit such way : 24Vac -15%= 20.4Vac to 24Vac+10%=26.4Vac
because i am going to convert 24VAC in to 24VDC
