- Joined
- Apr 1, 2011
- Messages
- 15,183
- Helped
- 2,900
- Reputation
- 5,812
- Reaction score
- 2,982
- Trophy points
- 1,393
- Location
- Minneapolis, Minnesota, USA
- Activity points
- 113,742
1) What your suggestion on Post #34 circuit? As per that circuit both relay should connect at the same time it connects in alternate way, like one is ON and other is OFF, i am interested to understand logic of this circuit
You can drive the second relay by inverting the signal to the first relay.
You showed progress by drawing your own schematic. I suggest you continue working on that.
Also, there are relays known as double-pole double-throw type (DPDT). These have two separate sets of contacts which would allow you to do what you want, all in one housing.
2) Post 39 Falstad circuit really helps me to understand the operation of the circuit, but that circuit operates on 400 ohms coil resistance of relay, but in my case i am using T7CS5D-24 relay parts from Tyco, its having 1600 ohms coil resistance, what type of modification i have to do to drive this Tyco relay? One limitation is i can not increase the power supply from 24VDC
I used 400 ohms only as a guess.
Since yours is 1600 ohms then it is likely to work on the 21 or 22 V coming from the charge-pump supply.
You should test it to find out what is the minimum voltage that will activate it.
3) Can you suggest me any Op-amp part number which is low cost and perform the operation, what we are looking for in Post #34 circuit.
The op amps can be general purpose. You need to use a type that can withstand 24 V at its pins. The all-purpose 741 may suit.
You have to comply with the specs. For instance, the inputs are not supposed to be exposed to a differential of greater than +5V or -5V. This may or may not occur in your project.
4) This 'Full-wave Rectifier with Smoothing Capacitor' circuit is efficient to generate smooth 24VDC (i mean pure 24VDC)? do you know any such compaq part which perform this action?
This power supply is practically the most popular type on the planet. It is reliable and easy to make, even for beginners.
Compaq may make such a supply however I'm not familiar with Compaq parts lists.
