Updating values in an Orcad PCB
Roel
Member level 2
Member level 2
Belgium
I've designed an Orcad PCB. Now I want to make changes to it. For example: I want to change the values of some resistors. When I change the value in the schematics and I click on 'Run Eco to LayOut', the new netlist is loaded into the LayOut (= the board) but the values are not changed. How do I change the values withouth deleting the component in the LayOut ?
Roel
hartsa
Member level 1
Member level 1
in layout just doubleclick a component and write new value
Roel
Member level 2
Member level 2
Belgium
Updating values of components
Is there no other solution?
The PCB and schematics are quite complex. It will be a lot of work.
There should be an automatic solution.
Does anybody now if I send the PCB to an assembler which values he will mount, the ones mentionned on the schematic or the ones on the board?
For example: at this moment I designed a resistor of 1K in the schematics and layout but when I change this to 4K7, in the schematics the resistor will be 4K7 but the value in the layout remains 1K. Wich value is used in the assembly files?
Roel
binu G
Advanced Member level 2
Bangalore
u may can solve this problem by using a latest eco by downloading frm the cadence website
