bongosontan
Newbie level 6
Hello everyone,
This might be a stupid question but my brain is not braining so this might be a very trivial problem that I can not figure out myself at this moment. Here we go:
I am trying to design a simple frequency divider circuit in verilog :
And here is my corresponding testbench:
This code is working fine on behavioral simulation but when I synthesized it and checking the simulation with the synthesized netlist, all the outputs are coming as 0 in the beginning due to reset and then undefined (x) for the rest of the simulation.
I might be missing something here. Can anyone point out the mistake that I am doing here? Thanks in advance!
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 `timescale 1ns / 1ps module Clock_divider(reset, clk40, clock_out_2, clock_out_5, clock_out_10); input reset; input clk40; output reg clock_out_2; output reg clock_out_5; output reg clock_out_10; reg[27:0] counter_2=28'd0; reg[27:0] counter_5=28'd0; reg[27:0] counter_10=28'd0; parameter DIVISOR_2 = 28'd2; parameter DIVISOR_5 = 28'd5; parameter DIVISOR_10 = 28'd10; always @(posedge clk40) begin if (reset) begin clock_out_2 <= 0; clock_out_5 <= 0; clock_out_10 <= 0; end else begin counter_2 <= counter_2 + 28'd1; counter_5 <= counter_5 + 28'd1; counter_10 <= counter_10 + 28'd1; if(counter_2>=(DIVISOR_2-1)) counter_2 <= 28'd0; clock_out_2 <= (counter_2<DIVISOR_2/2)?1'b1:1'b0; if(counter_5>=(DIVISOR_5-1)) counter_5 <= 28'd0; clock_out_5 <= (counter_5<DIVISOR_5/5)?1'b1:1'b0; if(counter_10>=(DIVISOR_10-1)) counter_10 <= 28'd0; clock_out_10 <= (counter_10<DIVISOR_10/2)?1'b1:1'b0; end end endmodule
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 `timescale 1ns / 1ps module tb_clock_divider; reg clock_in, reset; wire clock_out_2, clock_out_5, clock_out_10; Clock_divider uut ( .reset(reset), .clk40(clock_in), .clock_out_2(clock_out_2), .clock_out_5(clock_out_5), .clock_out_10(clock_out_10) ); always begin clock_in = 1'b0; forever #400 clock_in = ~clock_in; end initial begin reset = 1; #800 reset = 0; end endmodule
