Test Pattern Validation using Synopsys TetraMax
asbag
Newbie level 5
Hi all,
I am very new to the field of DFT and ATPG.
I have generated test patterns using Synopsys TetraMax.
And i don't how to validate these patterns. What should i do ?
Does anyone has any tutorials to verify these patterns again the netlist using simulators like modelsim or vcs ?
Best Regards
Re: Test Pattern Validation
just use this pattern as input to the Design, and see the waveform or output file for reference!
Hey Hi,
What you can do is simulate the design using this pattern. You can do it in Tetramax itself. Under the simulation tab you can check your patterns.
Hope this helps.
Hi all,
Thanks for your helps.
I have run test pattern simulation using VCS successfully.
Regards,
from where I can install tetramax atpg tool can you help me please
Hi all,
Regards,
Can you let me know the steps you followed to do the pattern simulation using vcs?
Thanks
