software use for calculating PCB details
taring77
Full Member level 2
Full Member level 2
Hi all,
anyone know of software that can calculate impedences, and details (e.g trace width, PCB thickness) when u input RF details e.g frequency etc
I don't know if this helps, but Protel lets you run a signal integrity check after you have your board laid out...
- Nobody
- Stays out of RF land as much as possible!
AppCAD from A_gilent...!!!!!!!!!!!!!
It is free....
you can look into the site called alrpcb.com.uk for some information related to thickness,temperature etc.....
Regards
Rame
i rather suggest to use txline or polar si8000 for calculating impedance as well as thickness,etc
Hi All,
I propose you these file excel
To use excel we need the formula to calculate rite?
Where can I refer the formula? there were different formula shows in the net
