Single-reactance compensation circuit
promach
For the following single-reactance compensation circuit, how to derive equation 6.2 for w' ?
It seems you forgot the attachment.
I have solved the original question above (just substitute eq. 6.2 into eq. 6.1 will do). What do you mean by attachment ?
Now, I am stuck at deriving equation 6.6
Besides, what is the significance of maximizing susceptance (dB/dw = 0) ?
For some reason I was not able to display the text you attached to the post. Now it's OK.
However the susceptance by definition is the imaginary part of the admitance, so starting from (6.3), analyzing each of the three terms separately we have:
Im(jwCp) = wCp
Im(1/(jwLp) = -1/(wLp)
Im(G)=Im[1/(R+jw'Ls)]=Im[ (R-jw'Ls)/(R^2+(w'*Ls)^2) ]=-w'Ls/[R^2+(w'*Ls)^2]
That is Bnet= Im(Ynet) = wCp - 1/(wLp) -w'Ls/[R^2+(w'*Ls)^2]
now simply take the derivative with respect to w and equate the result to 0 under the condition w=wo.
but how to get in particular the last term, 2*Ls / R2 ?
Take the derivative of -w'Ls/[R^2+(w'*Ls)^2] with respect to w, remembering that w'=w*[1-(w/wo)^2]
then put w=wo, that means all the terms [1-(w/wo)^2] will go to 0
but if I apply what you said about the last term, then the last term of eq.(6.6) should be ZERO instead of 2*Ls / R2 ?
No, you have first to take the derivative and then apply w=wo to the resut of the derivative calculation.
Yes, just apply the derivative properties.
    promach
There is a small mistake in your own expression of w'
wo is located at the nominator, not the denominator
Sorry, you are right. The derivative dw'/dw is then
1+(wo/w)^2
when w=wo
dw'/dw = 2
that is the same as before but with reversal in sign (in my previous post I didn't check the sign)
in post #3 , what is the significance of maximizing susceptance (dB/dw = 0) ?
and how is it related to quality factor of both the shunt and series circuits in figures 6.1a and 6.1b ?
Note: the picture screenshot is taken from Broadband RF and Microwave Amplifiers
No, I am trying to learn more about Class-E power amplifier before building it in LTSpice.
For the parallel - series resonant network the merit factor is given by Q=B/G (susceptance/conductance), while for the series - parallel resonant Q = X/R (reactance/resistance).
We know that the bandwidth is inversely proportional to Q, then to maximize the BW we have to lower the Q. Since the conductance or the resistance are fixed by the load, we can act only on susceptance or the reactance.
We can limit to the first topology. In this case at resonance (wo) B=0. In order to have a wide band we have to keep a low B around the resonance point.
We can do this forcing dB/dw=0 at w=wo
Since we have coupled parallel resonant followed by series resonant element with the same wo, the susceptance, starting from wo will be negative, while going back from infinite will be positive (as already said will be 0 for w=wo).
Then in-between positive and negative values (that is around wo) there will be an inflection point defined by dB/dw=0 at w=wo
The same if we consider the other topology with impedances (but the sign of X, with respect to the frequency, will be reversed compared with the sign of B).
    promach
Wait, why For the parallel - series resonant network the merit factor is given by Q=B/G (susceptance/conductance), while for the series - parallel resonant Q = X/R (reactance/resistance). ?
The attached document also does not explain this.
  • RF Circuit Design - [Ch2-1] Resonator and Impedance Matching.pdf
We know Z=R+jX while Y=G+jB, furthermore Y = 1/Z this means:
Y = 1/(R+jX) = (R-jX)/(R^2+X^2) so that G = R/(R^2+X^2) and B = -X/(R^2+X^2)
Q = |X|/R = |B|/G
you can choose to use impedance or admittance depending from the simplicity of the calculation but, of course, the final result is always the same.
By the way, in my previous posts I've omitted the modulus (| |) in the Q definition since usually is implicit.
    promach
Why starting from negative ?
Simply calculate the limits of eq. 6.3 and eq. 6.10 for w-->0 and w--> infinite
    promach
