Setting Calibre RUN PATH variable
Subhash
Newbie level 6
Bangalore, Karnataka, India
Kindly request help to set the Calibre run path for all the users in a project
I would like to set the run path as a project specific variable, so that when a user opens the Calibre Gui the run path should be automatically loaded.
Regards,
Subhash
It probably is not a good idea to have multiple people running from the same directory -- there will be filename collisions unless you are careful, and quite possibly issues with space, depending on the size of the input.
That said, if you really want to do it, create a runset with the settings everyone should be using. Reference it in the environment variable MGC_CALIBRE_DRC_RUNSET_LIST, and add that variable into the wrapper script the project team uses to call Calibre interactive. (Or have everyone add it to their configuration settings.)
The documentation ($CALIBRE_HOME/docs/pdfdocs/calbr_inter_user.pdf) can tell you how to create & save a runset, use multiple runsets, and so on.
As an additional comment; calibre enables you to add pre- and post-triggers (shell, python, perl, what-have-you) to the runs, making it possible to for example run tests in a separate area and then copy the interesting files into the shared project area for other team members use/inspection/history.
