Tukan
Junior Member level 1
Hello guys,
I would like to ask you question about following RF modules:
the first one is:
https://www.sos.sk/a_info/resource/c/pdf/tx4msil.pdf
and second one:
https://www.sos.sk/a_info/resource/c/pdf/txsawboost.pdf
First one has output power about 2 dBm and uses PLL oscillator
and second has output about 28 dBm what is much more then first and uses the SAW osc.
Can somebody explain me the difference between these two transmitters please?
Why the output power is such different?
Is the SAW oscillator on second one reason for higher power output?
Are these modules compatible in that way if I would use the same data output from MCU to the transmitter input?
Many thanks.
the first one is:
and second one:
Many thanks.
