Question about USBc connector and its footprint
Hawaslsh
Full Member level 2
Washington DC, USA
Hello All,
I was looking through a few USBc parts for an edge mount PCB and i came across a connector that confused me and I thought I'd ask the community. The part in question is the UC-31PFFH-QF7001, I linked the data sheet i got from the company.
Above is the footprint and 3D model from the company. Each top side (orange) pad/net has a corresponding via associated with it. I can't tell from the drawing in the data sheet, are the pads and vias internally connected through the connector? For example is B6 (NetR12_2) internally connected to A6 (NetR12_2) and there is no need to route a trace connecting them? I suspect this is true for convivence of routing, but I wanted to ask instead of assuming.
Thanks in advance,
Sami
FvM
Super Moderator
Staff member
Bochum, Germany
Read the datasheet thoroughly. Signals with different name have different function will be normally not connected to each other.
Only a few signals use multiple pins, e.g. GND, Vbus.
KlausST
Super Moderator
Staff member
I don´t think that the 4 VBUS pins are connected inside the connetor.
I recommend to connect them all on the PCB.
Klaus
RCinFLA
Advanced Member level 2
Because USB-C can be plugged in either direction there must be mirrored connection duplication in the socket. USB-C jacks typically do not internally connect the mirroring in the actual USB-C jack, leaving it up to the PCB layout to make the common mirrored connections.
LaTeX Commands Quick-Menu:
