Problem with simulating PLL in FF condition
semitao
Junior Member level 3
Hi, all.
I have a problem in my pll design. When I simulate the PLL circuit in tt&ss conditions, the result is OK. But when I simulate in ff condition, the output voltage of loop filter has periodical spikes. I am confused, who can help me?
thanks in advance.
Re: A problem in PLL
Dear semitao :
Have you checked your PFD output signals?
mpig
A problem in PLL
it is obvious that your pll is not stabel in ff. please check your pll loop in ff corner
i am a beginner in the PLL field. could someone tell me some useful books or papers about PLL?
thanks a lot!
Added after 3 minutes:
could someone tell me some tools to simulate the circuit of PLL?
A problem in PLL
I do not think it's stability problem. However, you do have phase margin issue. There is so much ringing in loop dynamics.
The huge spike looks like some coupling to control line voltage? (there is no way to debug in detail)
i have the same problem
the spike is appear periodly, and i think my pll is stable
Added after 2 minutes:
check the period of this signal , is it a reference spur or a VCO spur
khouly
khouly said:
what is ur loop filter topology , and what is the BW of ur loop ?
about the PLL resources
search this fourm u will find alot
also check these lec's
h**p://users.ece.gatech.edu/%7Epallen/Academic/ECE_6440/Summer_2003/ece_6440_su2003.htm
also check
R.Best PLL book it is great start
khouly
thanks a lot! very great help!
A problem in PLL
Hi, khouly
my loop filter is 2nd orde passive filter, and my pll bandwidth is 900KHz.
hi,semitao,
there are several reasons which may cause the phenomenon.
firlst, it looks like that the prescaler or divider doesn't work very well in long period. Please check them.
second, make sure there is no interference at this frequency.
third, please the PM of PLL.
fourth, ... forthur thinking...
to find the real fact, more detal information should be given.
liuliu
May be current mismatch in the pump happened in the ff corner.
A problem in PLL
yes
it is the current mismatch in the pump
i got the same problem too!!
i am a beginner in the field of PLL, could someone tell me some sumulation tools of the design of PLL?
thanks a lot!
thanks a lot!
hi liuyonggen_1
you can use matlab to simulate the pll in system level
spectrerf is a good simulation tool which evaluate your pll in detailed in system level or transistor level
A problem in PLL
If it is the current mismatch problem, why this phenomena is periodical?
I mean, if there is current mismatch, the voltage should have some trends, always decrease or increase.
The current mismatch in pump cause the phenomena "reference spur".
For details, pls ref TI'S application note.Sorry,I forget the name of that material.
Maybe some other notes will explain it more clear.
A problem in PLL
ckeck your CAD tools,do you set it right?i had the same problem before. the corner of tt and ss is right,but ff is failed.
A problem in PLL
hi, xusoso,
How did you solve this problem?
A problem in PLL
Check the PLL if there is any portion running at 25KHz (1/40us) to trace back what causes that.
