PowerPCB/PowerLogic Library Conversion.
richardrooney
Newbie level 6
Newbie level 6
powerpcb library
I have some very old PADS V2 library parts and I now want to convert them to PADS V4. I have the V3 to V4 conversion program but I need to convert from V2 To V3 first.
Does anyone have a program to perform the V2 to V3 conversion ?
Richard
powerlogic library
Richard
I believe the program I need is : "Libconv3.exe"
Richard.
power logic library
which is the version that you want convert .
library for
Powlogic 1.1, 1,2 to ....Powerlogic 5.
I have all.
powerpcb,powerlogic
V2 to V5 should do it.
Can you send me the relevent converters please ?
R.R.
power pcb convert 1.0 version
library conversion there will be tools in the folder where the software is installed
that can be used for the conversion
library conversion pads
If you are unable to convert the library you could open up the older
design in the new tool. Then select the decals and save to the new
library. It isn't as easy as a direct convert but it is much better than
rebuilding the parts by hand.
JerseyD
power pcb library convert
powerpcb5.0 suit has Libconv3.exe
old powerlogic to powerlogic converter
Is this what your after, V2 to V3?
Duplex
