Power Supply 0~30V, 0~2A
0-25v power supply project
the ps you linked, looks good.
but is there no bom? i can only locate components on the schematic??
/Kyndal
Reactions: dobble
    dobble
lm723 10 amp power supply schematic
I am going to make this project in freeware Version of Eagle 4.11...the board fits ...but going to take some time...may be two three weeks...I have to do it for my PCB guy..then a BOM will automatically be generated...but it takes a lot less effort to generate BOM from the posted sheets at the web page. May be if you contact the gentelman..he can help.
Regards
power suply 0 30v 0 2 amp
kewl!!
post it here when you have bom / pcb?
would be nice..
/Kyndal
psu pcb 30+30v
Hi all
In this link ht*t*p://rfr.htmlplanet.com/electronics.html we can find a very good power supply project using the old but very good LM 723.
It is voltage ajustable ( 0..25v) , current ajustable and protected.
It may works with loads about 10A.
In the description we may see how to calculate various components to work with high current and voltage above 25v.
A must to see...
Best Regards
jackrs 8)
schema +/- 30v dual regulated power supply
hadihf said:
I am attaching Schematic and component placemet for the PS...i will post the PCB and component list tomarrow.
Regards
PCB is OK. What about components list?
power supply design (2a)
oops, forgot VR3 = 2.2k (Current Control)
I am using normal good quality pots for I and V control but they are sensitive. using 10 turns pots here will be a good choice 8)
Regards
what is 52 to power of 0
Regards
Hi... This is a topic a little away from the real one, but I saw the PCB design and I wonder which routing program did you use to draw it.
Those component drawings are included ?
Thanks !
0-30v-0-10a
I made it in E/a/g/l/e but quite a way back in 1999. Now I use only legal softwares for hobby projects.
Regards
Reactions: lamole
    lamole
schema alim lm723
anyone has triple outputs schemetic?
I tried to build this powersupply but on the parts lists it doesnt specify the value of VR3 , although earlier has been mentioned is 2.2 K and it controls current Is this still correct?
However it doesn't mention which does control the output voltage.? Is it VR1?, VR2?
I hope the author of this project it is still on it.
Re: power supply 5v 2a shema
visit https://usbmpthree.webs.com/make.html
It may be better to look here for the power supply, Has this is based on old design andn it had many of faults with like this was quoted
Many of the parts in the original project are too small so they over-heat, especially the tiny 2N2219 transistor that is used for Q2. Even the transformer is too small so it also over-heats.
The transformer voltage is too low so the project will never produce 30V at 3A.
The opamps have a max allowed supply voltage of 36V but it is 38V or more in this project with the transformer voltage too low.
This is a better supply and more up to date
https://www.electronics-lab.com/forum/index.php?topic=19066.0
