Power Supply 0~30V, 0~2A
hadihf
Full Member level 2
Full Member level 2
Planet Earth
power supply 5v 2a shema
Here is a simple power supply I made. It has full zero, "yes zero" 8) voltage contorl to 30V and current down to 5 mA and upto 2A. It has very low noise and good stability. I use it for everthing and it never let me down for past 1 years. Use large Heatsink. Enjoy.
:D Hadihf
power supply circuit 30v 2a
i'm working in laboratory power supply controlled digitally by a uC, so perhaps i could use part of your schema.
many thanks
double 30 v 10 amp. power supply
HI ! I HAVE A ARTICLE ABOUT PFC BASED ON THE DSP .I THINK YOU NEED IT ,SO I ATTACH IT HERE ,PLS ENJOY IT!
10 amp 30v supply 723
how do you change the voltage?
psu 10 ampers schema
There are two pots, marked "V" for volt and "I" for current. simple as that :D
Hadihf
design of (0-30)v,2a pwer supplies
Hi HARBERT,
Please attach the article about PFC
Thanks.
power supply+0 to 30v+schematic
Hmmm... Very Nice ...
May be only needs V/A metter ..
power supply design (0 to 30v, 0 to 2 amp)
Actualy I was looking for a PIC based A/V meter with 1X16 LCD but could not find one at that time. Now I just use a hand neld DVM. :D
Regards
hadihf
lm723 0-30v 0-10 a
Mmm normal you can click on something but i can't find't it to..
can sombody help us ?
Greetz
power supply 0-30v 2a schematic
Check out OP548 (I think it is called) a power OP with built in current limit.
That OP with a CPU with two PWM outputs will make a very few component PSU.
Check out TI for free samples sent overnight with UPS. Very impressive.
MrEd
0 to 30v and with load current from 0 to 10a
sorry, what is PS??
lm 723 power supli 0-30
Look at **broken link removed**
my power alimentation 12 volt 2a
I am attaching Schematic and component placemet for the PS...i will post the PCB and component list tomarrow.
Regards
power suplies 0 to 30v schematics
Hi..
looks good, this ps. although i am looking to make a
dual powersupply (yes then i can make 2 and put them together)
but my problem is.. i would like to make it 0 - 10 amp insted.
is it posible to change this circuit to fit that spec
(0-30 V 0-10 A)
or does anybody have other circuit that will fit this?
/Rune Kyndal
lm723 0-25v
For 10A, you'll have to double the transformer's current output capabilities, IE 12~15A, double if not quadriple the reservior capacitors capacity, and double again the series output transistors (parallel with the apropriate ballast resistors), assuming that the drive current is sufficient.
With series power supplies, the problem is obtaining low voltages at high currents, as the series drop transistors have to dissipate the extra power.
For example,-
If your input voltage is 36v, and your output is 5v at 10a, the series transistors have to dissipate 310W !!!!., and this for a 50w load :(
Cheers
sda
lm723-power-supply-0-25v
i know that i will need a large heatsink.. probally actively cooled aswell..
but i have a rather large "ring core" transformer, able to delivere 36volts at 20 amps (2x) which i would like to use..
and putting it in a 2a ps would be a waste :)
im looking at a velleman kit K7200RS it vis rated at 30 volts, 10 amps.
single supply. i would like to build this, but frankly the kit is to expencive.
i have component list but i need the pcb..
anyone got this? photograf of it will do!!
/Kyndal
LaTeX Commands Quick-Menu:
