PIC16F877A RS232 running at 38400bps
I metered the voltage and it is 4,9 volt instead of 5 volt. Could this cause the strange numbers ???
Also I use capacitors of 65 Volt, 1 uF. Do I need to use less voltaged-capacitors??
Does anyone has a schematic of a MAX232 that works ???
MAX232 circuit is given in MAX232 datasheet. A table also gives Capacitor values to be used.
I bought an RS232 to 0/5 Volt module in order to overcome the problem. I connected the Tx--->Rx in order to check if it sends the correct data.
It does not sends the correct data. I changed the baudrate to 9600 and then it sends the correct data.
As far as my major problem is concerned (that the my post belongs), could the 38400 bps be a problem for the strange numbers I get on the terminal PC, when I connect the PIC????
Zip and post your complete mikroC project files. I will test it using my EasyPICv7.
Here it is
  • PIC16F877A_Zigbee_data.rar
Try this code. Don't test on breadboard. Test on a soldered board.
Code C - [expand]
8
9
10
11
void main()
    UART1_Init(38462);                 // Initialize UART module at 38400 bps
    Delay_ms(1000);                     // Wait for UART module to stabilize
    while(1)
        UART1_Write_Text("DB7EHello World!");
        Delay_ms(1000);
Try this code.
Code C - [expand]
8
9
10
11
12
13
void main() {
    TRISC = 0x80;
    PORTC = 0x00;
    Delay_ms(200);                     // Wait for UART module to stabilize
    while(1) {
        UART1_Write_Text("Hello World!");
        Delay_ms(1000);
hello
try with a CR LF at the end of string
while(1) {
        UART1_Write_Text("Hello World!\r\n");
        Delay_ms(1000);
or simplest test
   while(1)
        UART1_Write('H');UART1_Write('e');UART1_Write('l');UART1_Write('l');UART1_Write('o');
        UART1_Write(13);UART1_Write(10);
        Delay_ms(1000);
The 16F877A which I have is dead. I have ordered two new 16F877A's. I will get it in another 4 days. Wait till then. Once I get them I will test it on EasyPICv7 and report back. I also have to get 16 MHz crystal.
Hello! I changed the PIC with a new one and finally worked!!!! Thank you all for your help!!!!
