ADC interrupt problem pic16F877A
yassineee
Newbie
General description of the system
A freight elevator is a mechanical device used to move goods or
equipment between several levels of a building (factory, warehouse, etc.). The size and capacity of the
cabin vary depending on the specific needs of the application. The lifting system
uses an electric motor that provides the energy needed to move a load
maximum depending on the needs of the application. In general, the system also integrates
several safety devices such as those linked to not exceeding the maximum load,
and safety relating to closing doors.
System Composition
A freight elevator control system serving 2 levels (ground floor + 1st floor) is built
around a PIC16F877 microcontroller operating at a frequency of 4 MHz, and includes the
following external devices:
- Motors controlled via L293D circuits (motor driver)
o 1 motor to raise and lower the cabin
o 2 motors to open and close the two cabin doors.
- Sensors
o A weight sensor (analog) to be connected to the ADC module of the PIC16F877
o A presence sensor at the doors (digital)
o 2 end-of-stroke sensors (digital) allowing precise stopping at the level
of the desired floor
A control panel serving as a Human-Machine interface and comprising:
- Push buttons
o 2 Up/Down control buttons to raise or lower the cabin.
o A button for monitoring the good performance of workers.
- An LCD screen to display messages.
- Indicator lights for visual signaling:
o Red: presence of obstacle near the cabin doors.
o Green: cabin in race.
- A buzzer for sound signaling
System operation :
 When powered on, if the goods lift is not on the ground floor, an action on the motor
allows it to be lowered, the doors are open, the LCD screen displays the message
“Ground Floor” and all the lights are off.
 An action on the “Up” or “Down” buttons ensures that:
o If no obstacle is present, the cabin doors close.
o The cabin goes up or down. The LCD screen then displays the message “UP” or
“Down” and the green light is on.
o If the end of travel is detected, the cabin stops, the green light goes out and
the LCD display shows “First Floor” or “Ground Floor” depending on the floor.
o Sliding doors open to allow loading or unloading
unloading, and the buzzer activates for 4 seconds.
 Closing the doors to continue the treatment described above is not
possible in the following two cases:
o detection of the presence of an obstacle in which case the LCD screen displays the message
“OBSTACLE” and the red light flashes
o exceeding the maximum authorized weight of the goods/equipment, at which
In this case, the “OVERLOAD” message is displayed and the red indicator light comes on.
In both cases, the buzzer is activated for 2 seconds.
 Cabin overloading directly affects productivity within the
the factory due to delays caused by untimely additional loading and
partial unloading obligatory in order to respect the maximum weight constraint.
Furthermore, a low load multiplies the round trips and leads to a loss of
time and energy. To control the work of workers, the system records
EEPROM memory:
o The number of overload attempts
o The number of strokes with a load less than 80% of the maximum load
 An action on the “Monitoring” button allows you to view for 10 seconds, these 2
performance indicators. For example :
“Overload: 2” and “Underload: 3” on the 1st and 2nd line of the LCD screen, respect.
 These two indicators can be initialized at any time by a prolonged action
on the follow button.
Required work
Session n°1 (week 9): Basic version of the project
A. Study of the architecture of the PIC16F877:
Draw up a comparison table showing the difference between the PIC16F84 and the PIC16F877
in terms of
 The number of Ports,
 The memories used, program and data, with their storage capacities
 Sources of interruptions
 Additional hardware resources
B. Development and simulation of the main program without the interrupt mechanism:
Considering the operation of the freight elevator in suitable conditions (without
take into account no detector or the use of the EEPROM module)
 Create an ISIS assembly including the PIC16F877 microcontroller, and the resources
necessary auxiliaries.
 Write the C code for the main function including the three configuration parts,
initialization and the main loop allowing:
 React following the action of one of the “Up” and “DOWN” buttons
 Control: the 3 motors, the LCD screen, the green indicator light, and the buzzer.
Note: At this stage of the project, activate:
 the motor moves the cabin for 10 seconds to simulate a race
complete between the 2 floors.
 Door motors for 3 seconds for opening/closing.
Session #2 (week 10): Implementation of the interrupt mechanism
 Incorporate limit switches into your system simulation model
(LOGICSTATE) by choosing the correct I/O pins.
 Also incorporate a presence sensor to secure the closing of the doors
sliding, and a red LED
 Modify code C to take into account the presence of these new sensors.
(interrupt configuration, main loop update and routine
interrupt)
Session #3 (week 11): Using the ADC module
 To protect the system against the risk of deterioration caused by excess weight,
incorporate a sensor to measure weight, at a suitable pin of the PIC.
This sensor can be simulated by a potentiometer.
 Update the interrupt routine.
I do the editing and the code until session 2 but the work of session 3 does not work I have a problem at the ADC interrupt level so can you correct my code please and thank you.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
#include <stdio.h>
#include <string.h>
//int adcValue;
//int tmp;
// Define LCD Connections
sbit LCD_RS at RC0_bit;
sbit LCD_EN at RC1_bit;
sbit LCD_D4 at RC2_bit;
sbit LCD_D5 at RC3_bit;
sbit LCD_D6 at RC4_bit;
sbit LCD_D7 at RC5_bit;
sbit LCD_RS_Direction at TRISC0_bit;
sbit LCD_EN_Direction at TRISC1_bit;
sbit LCD_D4_Direction at TRISC2_bit;
sbit LCD_D5_Direction at TRISC3_bit;
sbit LCD_D6_Direction at TRISC4_bit;
sbit LCD_D7_Direction at TRISC5_bit;
#define LCD_RS      PORTC.RC0
#define LCD_EN      PORTC.RC1
#define LCD_D4      PORTC.RC2
#define LCD_D5      PORTC.RC3
#define LCD_D6      PORTC.RC4
#define LCD_D7      PORTC.RC5
// Define Motor and Door Connections
#define MOTOR_UP_DOWN_IN1 PORTD.RD0
#define MOTOR_UP_DOWN_IN2 PORTD.RD1
#define MOTOR_DOOR_LEFT_IN3 PORTD.RD2
#define MOTOR_DOOR_LEFT_IN4 PORTD.RD3
#define MOTOR_DOOR_RIGHT_IN5 PORTD.RD4
#define MOTOR_DOOR_RIGHT_IN6 PORTD.RD5
//Define sensors
#define capteur_pos PORTA.RA1
// Define Button and LED Connections
#define BUTTON_UP   PORTB.RB0
#define BUTTON_DOWN PORTB.RB1
#define LED_GREEN PORTA.RA2   //chpin0->2
//#define LED_BLUE    PORTA.RA0
#define LED_YELLOW  PORTA.RA1
#define BUZZER PORTB.RB2
void configureIO() {
    // Configure ports for output as needed
    TRISD = 0 ;
    TRISC = 0; //
    TRISB = 0b10000011; //
    TRISA = 0b00000100;
    // interruption
    INTCON.GIE=1;
    ADIE_bit = 1;
    PEIE_bit = 1;
    //NTCON.INTE=1;
    //OPTION_REG.INTEDG=1;
    INTCON.RBIE=1;
    INTE_bit=1;
void initialize() {
     //affichage de test
     Lcd_Init(); // Initialize LCD
     Lcd_Cmd(_LCD_CLEAR); // Clear display
     Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
     Lcd_Out(1,1,"Hello World");
      //initialisation : Led - buzzer
      LED_GREEN = 0;
      BUZZER =0;
        //init motors
        //m1
        MOTOR_UP_DOWN_IN1 = 0;
        MOTOR_UP_DOWN_IN2 = 0;
        //m2
        MOTOR_DOOR_LEFT_IN3 = 0;
        MOTOR_DOOR_LEFT_IN4 = 0;
        //m3
        MOTOR_DOOR_RIGHT_IN5 = 0;
        MOTOR_DOOR_RIGHT_IN6 = 0;
        //sensors
        //capteur_pos=0;
 /* void adc_init() {
    ADCON1 = 0b10001110;
    ADCON0 = 0b10000001;
    //ADCON1 &= 0x0F;
    ADRESH = 0x00;
    ADRESL = 0x00;
int adc_read() {
   // Start ADC conversion
    GO_DONE_bit = 1;
    // Attends la fin de la conversion
    while (GO_DONE_bit);
    // Retourne la valeur convertie
    return (ADRESH << 8) | ADRESL;
  void adc_interrupt() {
    if (PIR1.ADIF) {
        int adc_value = adc_read();
        if (adc_value > 512) {
            MOTOR_DOOR_RIGHT_IN5 = 0   ;
            BUZZER = 0;
            delay_ms(1000);
            BUZZER = 1;
            delay_ms(20000);
            BUZZER = 0;
            MOTOR_DOOR_LEFT_IN3 = 1;
            MOTOR_DOOR_RIGHT_IN6 = 1;
        PIR1.ADIF = 0;
/*void interrupt()
{    //if(RB0_bit==1)
  if((INTCON.RBIE==1)&&(INTCON.RBIF==1))
    // si cause par rb7
    if(PORTB.RB7==1)
        //activation buzzer
        BUZZER = 1;
        delay_ms(2000);
        BUZZER = 0;
      INTCON.RBIF = 0;
 if(INTF==1)
/*void operateDoors() {
    // affichage ouverture
    Lcd_Out(1, 1,  "Ouverture");
    // Moteur mode: ouverture
    MOTOR_DOOR_LEFT_IN4 = 1;
    MOTOR_DOOR_RIGHT_IN5 = 1;
    delay_ms(3000);  // Open doors for 3 seconds
     BUZZER = 1;
    delay_ms(5000);
    BUZZER = 0;  // Stop doors for 5 seconds
    //affichage fermeture
    Lcd_Out(1, 1,  "Fermeture");
    //Moteru mode : fermeture
    delay_ms(3000);  // Close doors for 3 seconds
    //  interruption si sensor détécte obstacle  //
/*void MonterFloor()
{    Lcd_Cmd(_LCD_CLEAR);
     Lcd_Out(1, 1,  "Up");
     MOTOR_UP_DOWN_IN1 = 1;
     LED_GREEN = 1;
     delay_ms(10000);
     LED_GREEN = 0;
      if( MOTOR_UP_DOWN_IN1 == 0)
               capteur_pos=1;
               delay_ms(3000);
          else
              capteur_pos=0;
/*void DescendreFloor()
      Lcd_Out(1, 1,  "Down");
     MOTOR_UP_DOWN_IN2 = 1;
     LED_GREEN = 1;
     delay_ms(1000);
     MOTOR_UP_DOWN_IN2=0;
     LED_GREEN = 0;
     if( MOTOR_UP_DOWN_IN2 == 0)
               capteur_pos=1;
               delay_ms(3000);
          else
              capteur_pos=0;
    /*unsigned int ADC_Read_RA2() {
    unsigned int result;
    ADCON0 = 0b10001001;  // Configuration pour RA2 (AN2) en mode ADC
    ADCON1 = 0b10000000;  // Référence de tension VCC et VSS
    Delay_us(20);  // Délai pour la stabilité de la tension de référence
    GO_DONE_bit = 1;  // Démarre la conversion
    while (GO_DONE_bit);  // Attends la fin de la conversion
    result = (ADRESH << 8) + ADRESL;  // Combine les registres ADRESH et ADRESL
    return result;
   char txt1[]="hello";
   char txt2[]="nomFic";
   char tension[5];
   int i;
int main() {
    configureIO();
    initialize();
      ADC_Init() ;
    //ADCON0=0b10010001;
      ADCON1 = 0b00001110;
      //Lcd_Init();
      Lcd_Out(1,1,"Hello");
      Lcd_Out(2,5,txt2);
     // tmp = ADC_Read(0);  // Read analog value from channel 24
      //Lcd_Cmd(_LCD_CLEAR);  // Efface l'écran LCD
    //RB7_bit=0;
       /*adc_init();
       adc_interrupt(); */
   while (1) {
          i=ADC_Read(0);
          IntToStr(i,tension);
          delay_ms(1000);
          Lcd_Out(1,4,"hello");
          Lcd_Out(2,4,tension);
          delay_ms(1000);
    return 0;
this is all the details of the project .
I'm surprised you didn't also tell us what you've eaten for the last week.
You present an unmanageable amount of information, and then just say: "it doesn't work". What does that mean? Does the elevator go sideways? Does it speak in tongues?
Give us a concise description of what it does and doesn't do. What have you done to debug it? What do you see?
But the problem is your ADC interrupt routine is incestuous!
You call the adc_read() from inside the interrupt routine but to get to it the interrupt has to be generated by the ADC.
Restructure your code so you start the ADC conversion in your main() loop and when the ADC interrupt is generated, set a variable in the ISR to tell the main loop to read the ADC value. Then clear the variable so it is ready for the next ADC interrupt. If you do it this way, the code in the main() loop will execute in parallel with the ADC conversion so you don't get any unwanted delays while it wait for the conversion to finish.
Brian.
LaTeX Commands Quick-Menu:
