pcb layout of PIC controlled intruder alarm
BURGLAR ALARM
Can you post me a photo of the LCD which is turn on?
Re: BURGLAR ALARM
Hi, Thanks for taking care for me
Here my photos had attached please find it and rectify the issue
thank u
Re: BURGLAR ALARM
one more i attached please check it up
url=http://obrazki.elektroda.pl/28_1252161088.jpg]
[/url]
BURGLAR ALARM
OK, I see your problem now. This is because you are using 4 bit interfacing instead of 8 bit interfacing. That's easy to solve. Just connect pin 7, 8, 9 & 10 of your LCD to negative ground. That should solve the problem.
Re: BURGLAR ALARM
thanks for ur reply let me check it now and reply to u
Added after 38 minutes:
Hi Statofart
I tried but it stays same problem in that, please help me to solve it
pin 7,8,9,10 connected to ground, same problem is continue
thank u
BURGLAR ALARM
Can you post me a photo of your LCD with pin 7, 8, 9, & 10 connected to 0Vdc (-)?
According to the schematic, please check the following connection against your LCD and PCB board/breadboard.
LCD Pin
01 ----------------------------------> 0Vdc
02 ----------------------------------> +5Vdc
03 ----------------------------------> Contrast VR
04 ----------------------------------> Pin 6 of PIC16F877
05 ----------------------------------> 0Vdc
06 ----------------------------------> Pin 7 of PIC16877
07 ----------------------------------> 0Vdc
08 ----------------------------------> 0Vdc
09 ----------------------------------> 0Vdc
10 ----------------------------------> 0Vdc
11 ----------------------------------> Pin 2 of PIC16F877
12 ----------------------------------> Pin 3 of PIC16F877
13 ----------------------------------> Pin 4 of PIC16F877
14 ----------------------------------> Pin 5 of PIC16F877
Re: BURGLAR ALARM
hi
wat u posted about details of lcd connections same thing i had done in my circuit,but it seems same problem if u want to upload my photo i can
thank u
Added after 2 minutes:
If u hav any alternate schmatics, please upload to me so that i can change,
thank u
BURGLAR ALARM
Please upload the photo of the LCD after pin 7 to 10 is grounded. And replace this program too. Attach is the datasheet for your LCD. Please study carefully to initialize.
BURGLAR ALARM
The documentation of my display ... if it can help you?
I work to change the alarm and improve with the help of stateofart
One of the amendments is the economy of sensors areas
1 sensor area will enable 2-way
as soon as I finish this post I alarm the new pcb
https://www.youtube.com/watch?v=cVpsRWaCklk
BURGLAR ALARM
I thnk this project might be of help especially to me as a fresh beginner in Microcontrllers and starting wit PICs
Re: BURGLAR ALARM
Friend seti75 I have 3 PCB's the original of the magazine EPE 2002e another of a friend from Peru/Lima, and the one that you sent to this forum.
I already have two executed circuits but I didn't get to have success.
I thank that when you have new PCB and circuit executed in the proteus sends me please.
Merci mon ami
Re: BURGLAR ALARM
ok, I suggest the PCB in the forum, which I completed the circuit.
I board made several changes to the alarm.
changes --->
1 sensor can activate 2 zones
2 zones in Entry (delay)
time "death", after and during alarm ---> zones 1.2.3.4.5.6.7.8.
... example,
an intruder , it activates a zone, alarm, he ran away ... if it passes through areas under surveillance, it will activate other areas , is not very clever!
Change will be a zone in alarm, stop all monitoring for 20 minutes
20 minutes after the alarm returns to monitoring (choice of time RC)
BURGLAR ALARM
You can use 555 timer IC to trigger the bell output using the RC concept. The system Bell-On-Time will use to disable the system. Don't that much more easier?
Re: BURGLAR ALARM
Hi,Stateofart
Sorry for my Late Reply
Please help me to solve my Isuues, Still LCD not initialized properly so please guide me some Corrected ASM files
Thank u
BURGLAR ALARM
I think let's not waste anymore time if you are in the hurry for completing this project. Just get another brand of LCD. Example, Powertip LCD. Previously, I was like you too. Truobleshooting the LCD initializing for month. But finally, Igive up that LCD. And purchase another make of LCD. And it works with this program.
Re: BURGLAR ALARM
I board completed the modification of this alarm
I board add a delay between two alarms, if an area is put into alarm and the intruder ran away with another road or it there's also an area under surveillance it will also triggered this area
with this change, the alarm will still standby, 10 minutes
after an alarm, other changes, a sensor area, the alarm is tripped 2 times!.
(This was originally an alarm sensor triggers the alarm and is finished for this sensor! ... it does not appeal to me!)
the video .. and soon the PCB.
https://www.youtube.com/watch?v=ZXGnmoYCdic
Re: BURGLAR ALARM
If you have completed the circuit you show in the video, I'm interested in it.
Please p.m. me or post it here in ares format. Thank you.
Re: BURGLAR ALARM
it's over, sorry, I did not have time to return to the forum
(much work)
the new package which works perfectly
Re: BURGLAR ALARM
Friend Seti75 very good service, but for this image it is difficult to execute, without he/she has more details, if possible I thank a lot that allowed me completely that is able to execute this alarm. There is a long time that I am trying fazê-store tried for the Revista APE, but I didn't get to render.
Merci pour tout ce pouvoir d'aider beaucoup
