Opinions on Lattice xPLD performance
jay_ec_engg
Full Member level 3
India
how to assign pins with lattice
Hi freinds..
have anyone worked on Lattice xPLD... how good it is for fitting.. and hows the isplever tool ?? is it comfortable ?
lucbra
Advanced Member level 2
Belgium
Re: Lattice xPLD
The XPLD is quite flexible. I found that fitting a design in a std CPLD harder than fitting it in XPLD.
I have now ispLEVER 4.2 - runs smoothly
Regards,
my_garden
Member level 4
Lattice xPLD
HI jay_ec_engg,
Be carefule if you use XPLD's ram resource. It will make the P&R difficulty. And do not try to lock the pin by yourself, let the software to assign the pin itself.
And use the version later than 4.1. Try to use the 3rd part EDA software to fit the HDL, and then use LEVER to compile the edf file.
jay_ec_engg
Full Member level 3
India
Re: Lattice xPLD
Hi my_garden..
Is there any difficulty in assigning pins by ourselves ???
I already assign pins for hardware.. and coding is half the way...
Please reply me
Jay
my_garden
Member level 4
Lattice xPLD
Hi Jay_ec_engg,
If you haven't use XPLD's memory resource, you do not need to care assigning pins.
Because the ram resource wasting too many router resource.
jay_ec_engg
Full Member level 3
India
Re: Lattice xPLD
Do you know about SRAM configuration option with XPLD ?
How exactly can we implement it ???
RAM which u are talking about is this SRAM for configuration or RAM used for our application ???
Jay
my_garden
Member level 4
Lattice xPLD
HI Jay,
The Ram i talking about is the ram which is configed from MFB.
XPLD can be programmed like a CPLD. Do not to care its configuration progress.
eBond
Newbie level 3
Re: Lattice xPLD
Hey Jay now you can try with LAttice XP device as its teh best noon Volatile FPGA Infinite times reconfigurable.. try that out .. if you need an hekp lemme know
jay_ec_engg
Full Member level 3
India
Re: Lattice xPLD
Havae u used this FPGA ?? I herad of it but do not get any response from others about how good it is...do u find it flexible and easy ?
my_garden
Member level 4
Lattice xPLD
Hi Jay,
XP and XO are the new products of Lattice. These two products use the same XP technology just like XPLD. But they are much cheaper than XPLD. They are all LUT base device. XP is focus on low cost FPGA, XO is focus on large CPLD.
soccer
Full Member level 3
Lattice xPLD
what is a xpld?
lucbra
Belgium
Re: Lattice xPLD
XPLD is just a name that Lattice has used to distinguish between this device family and a standard CPLD.
This device has FPGA I/O options, Memory and PLL's, and it also configures through a parallel uP bus besides the standard JTAG/B-Scan.
Regards
