Dear sir,
how to increase or decrease delay between two pulses on a same signal. i want after every two pulse need some delay. expecting verilog code. i tried verilog code both u down clock pulse width vary or getting delayed out. i dont want that
See my reply @ #6 and subsequent replies in the post https://www.edaboard.com/threads/361519/ to get an idea how to insert delays between two clocked pulses. Use counters for achieving delays between the pulses.
Again - Show us what you have done and understood.
Dear sir,
if you post your code, its better, you will get more help for correcting the code. from your above statement its not clear what type of signal you want
Anything you post can be criticized by anyone for whatever reason (right or wrong). The fact is you've made posts that want others to do your work for you. This forum is not a free consulting service.
If this is truly 0.01% of your work then give this to someone else who is capable of doing the work without having to get on edaboard to do their job. Hmm, just occurred to me, perhaps you are really saying you don't need to do your own work (as you get others to do it for you, i.e. edaboard) and you only do 0.01% of your actual work. :wink::laugh:
