microwave filters - waveguide
Mazi3
Full Member level 1
Europe
Hi!
I would like to know how to design and then build filters in waveguide ; only digital and interdigital version, with open end (if there is lambda/4 to the end...).
I have some experience in building such filters, but none in the design.
Is there eny useful software, or exists theory with "cookbook"?
Regards!
g86
Full Member level 4
Full Member level 4
On top of antenna :))
For software: you may synthesys with eseptum or cocafil and simulate with microwave wizard
:!: :idea: :?:
Mazi3 said:
Hi!
Regards!
Mazi3
Full Member level 1
Europe
tnx, I'll se If demo will help me :) but they cost a whole bunch :)
I would like to design filter for 1.42G, 2.2GHz, 8-9 GHz
g579
Full Member level 6
Full Member level 6
Somewhere
I think you use the word "waveguide" incorrectly. In general it means you use a (square or round cross section) tube as a transmission line.
Mazi3
Full Member level 1
Europe
tnx, yes, i mean waveguide as a line, whre the fingers (resonators) are installed.
I've downloaded the demo software, but it's unusable. Demo has limits in frequency (>20GHz) which is not suitable for me. If there would be no "recipes" i'll try to do it in cut&try method :)
Maybe I'll get some recipes about doing that :)
Is there anybody who would help cutting the pipes? :) or have some ideas how to do it first time :)
Borber
Advanced Member level 5
on third flor
filter
I have few programs for calculation interdigital and waveguide filters.
This can help I think. On basis of this software I have build filters successfuly.
LP Borber
Mazi3
Full Member level 1
Europe
Hi!
Are those programs support filters with open ends? they are much simpler to build than those which are closed.
I would like to build filter from square aluminium pipes (standard sizes). does they support to enter physical dimensions and then it calculate the response?
Regards!
Borber
on third flor
Included are programs for interdigital filter + GW Basic, waveguide filter and Excell file. Digifilt2.bas calculates open end filter build with square tube. It is written in GW Basic.
LP Borber
flatulent
Advanced Member level 6
Middle Earth
scale the dimensions
One trick to avoid the frequency limit problem is to scale all dimensions inversely by the same factor as the frequency. This will get you close enough to use an analysis program to check and fine tune the scaled design.
