LVDS Pin Assignment in Lattice
imbichie
Full Member level 6
Full Member level 6
Cochin/ Kerala/ India or Bangalore/ Karnataka/ Ind
Hi Friends,
I am working with Lattice ECP2 FPGA, Now there are some LVDS Input and Output ports in my Design. This is the first time i am using the LVDS ports in my design.
Can i directly assign the LVDS port to the +ve pins of LVDS? Means shall i use any buffer before the assignment to the LVDS pin??
If i am assigning the port to the +ve LVDS pin, then is the FPGA automatically assign the complementary pin to the -ve pin of LVDS??
Thanks in Advance
If I remember well, you can just assign the signals to the I/O. This is done in the spreadsheet view (Diamond). In the same view, you chose the desired I/O standard - in your case this becomes LVDS25.
Thank you for your Reply,....
So no need of any LVDS Buffer before assigning to the pin. Means just assign the port to the +ve LVDS pin and assigning the type as LVDS25 is enough....?
I just assigned the port to the +ve LVDS pin, then i found (*.pad) that the ispLever itself assigned the complementary to the -ve LVDS pin.
So is it enough, means will it work as LVDS, with out using the buffer at the port???
Thanks in Advance
Good - if ispLever (you haven't upgraded to Diamond yet?) assigned the complementary buffer, you are assured that it will send out LVDS signals. However, there is no protocol involved (8b/10b, serdes, ...) That is something that you need to write yourself.
Good luck
