memarian
Full Member level 5
Hello guys,
I'm designing a board for communication between 2 instruments (and doing some other stuff) with these specs :
Wire length : Between 10m ... 30m (depends on the installation environment)
Available wire/cable type : 2 wires of a simple 4x1 or 4x1.5 cable. These aren't twisted pair.The cable is currently installed and the i can't change it or install anything else.
Baud Rate : Minimum 2400bps half-duplex or 1200bps full duplex(but i prefer 9600bps half duplex).
I wanted to use RS485, but i can't (There isn't any available twisted-pair).
On both ends there will be a MCU (Currently is STM32F103) and power will be available , so there won't be any shortage in power.
I'm currently thinking about using 1-wire link with drivers like DS2480B.
Is there anything that i'm missing? any other recommendation?
BTW : on the other 2 conductors of our cable there will a AC 40V-2..4A Power supply that will be rectified
and used for driving a dc motor at one end of the cable.
Thanks.
Thanks.
