[ARM] Long 1-wire link (10m ... 30m)
memarian
Full Member level 5
Full Member level 5
Hello guys,
I'm designing a board for communication between 2 instruments (and doing some other stuff) with these specs :
Wire length : Between 10m ... 30m (depends on the installation environment)
Available wire/cable type : 2 wires of a simple 4x1 or 4x1.5 cable. These aren't twisted pair.The cable is currently installed and the i can't change it or install anything else.
Baud Rate : Minimum 2400bps half-duplex or 1200bps full duplex(but i prefer 9600bps half duplex).
I wanted to use RS485, but i can't (There isn't any available twisted-pair).
On both ends there will be a MCU (Currently is STM32F103) and power will be available , so there won't be any shortage in power.
I'm currently thinking about using 1-wire link with drivers like DS2480B.
Is there anything that i'm missing? any other recommendation?
BTW : on the other 2 conductors of our cable there will a AC 40V-2..4A Power supply that will be rectified
and used for driving a dc motor at one end of the cable.
Thanks.
I would have thought that at 9600bps RS232 would be suitable for a distance of 10 to 30 metres so long as there is not too much electrical noise in the environment
I only have 2 wires available for this link and RS232 needs 3. (this link is a 2 way link not 1 way)
About the environment noise: the environment noise varies with every installation ,and also the power supply of a motor is on other 2 conductors of the cable.
you could OR the TX and RX onto two wires to give you half duplex communication using a master/slave protocol
there was a post on the microchip forum discussing this
https://www.microchip.com/forums/m500934.aspx
You can e.g. use the LIN bus standard. Or any self-designed wired-OR/wired-NAND bus.
It seems that LIN BUS is suitable for my project and transceiver chips are easily available & cheap!
I will study more about LIN BUS and see what happens.
i used to run 10m RS232 cables in the lab easily to one monitor using diode OR and 10k to a status pin at V- to an RS 232 dumb terminal to watch communication in both directions at 9600 in the 70's with no problem, but 6 port MuX boxes to printers would occasional have errors in the office from ground noise , easily fixed as I replied earlier.
