cks3976
Full Member level 6
Dear Group,
I am using Promos DDR -II memory V59C1512164QDJ3I in a design. We have currently made 70 prototype cards with this memory. And a significant number of cards (20%) in this lot are failing during system start-up (that is when the system is in room temperature). System log suggests that the Write to DDR-II have failed.
However after several reboots and when the system becomes bit more warm the card start functioning well (well.. most of the times).
I have tested the Card for possible drop in power or slip in the clock during start-up, but I could not see an issue.
BTW, initial spins of this Card were using DDR from a different make (Nanya) and we never faced any issue. I also tried using a Nanya device on this new set of Cards, but that failed too..
I feel the issue is not in Memory, but in the Card. Can you please suggest me what can be done further to analyze the issue ?
Thanks in advance,
CKS
Thanks in advance,
CKS
