sharethewell
Member level 5
Urgent help needed! Impedance matching problem
I am having an issue when I simulate a RFpower amplifier in a test bench. In the picture, all those inductors and capacitors are representing paracitic inductance and capacitance for bondwires and pads that are connected to the output of my PA.
So here is the question. The 50 ohms series and 25 pF capacitor parallel have huge effect on my output waveform. Basically, the 50 ohms series works like a voltage devider so that the signal(voltage) delivered to the load is much smaller than without using the 50 ohms series. So how can I fix this issue? Any method I can try?
The other thing is about the 25pF parallel capacitor. It has a big effect on my output waveform as well. Is there a way I can minimize the impact of the this capacitor?
Adding inductors to cancel it out? Any idea?
By the I didn't put my L matching network in the picture yet.
