How to design a low supply voltage bandgap that works under the 1.5V supply voltage?
wangjianping4213
Newbie level 1
how to design a low supply voltage bandgap that can work under the 1.5V supply voltage?
Re: bandgap
can you state your question a little clearer... r you trying to design a bandgap supply that gives a output of 1.5V or are you designing a bandgap supply which uses 1.5V and gives a output voltage less than 1.5V....
Re: bandgap
do u mean ur power supply is 1.5V?
bandgap
That is a huge question; suggest you search book with keyword "bandgap" or " voltage reference" in "EDA book download"
bandgap
see this paper
H. Banba et al .. A CMOS Bandgap Reference Circuit with Sub-1-V Operation. IEEE J. of Solid-State Circuit, Vol 34 pp.670-674, May 1999
Re: bandgap
under 1.5V power supply bandgap has been done by many people.
many circuits work in subthreshold region in low voltage supply.
Re: bandgap
First build a standard 1.2v output BGR then generate current through a resistor. Mirror this current through another resistor then you will get 1.5v BGR. Remember to match these two resistors.
bandgap
find in the ieee with key word "bandgap" "low voltage"
