Log into Ansys Customer Portal and download the HFSS intro. files. Go through their tutorials on how to create structures.
After finishing the tutorial, you should be able to draw your patch antenna.
Post your question brother and people will help you out.rather than asking random questions all the time.there are plenty of guys if a certain person doesnt have experience with it others willbe able to help
i want to draw antenna with different dimension of different kind of figures.out of which some are not present in HFSS software. i need help in this regard.
thanks
Regard
abdul wahab
A patch antenna is a rectangular structure. The layers should be as follows.
Top = Metal
Middle = Substrate
Bottom = Ground Metal
Draw one box for each layer. All of shape are rectangular boxes. It should be an easy exercise once you go through the microstrip line tutorial from Ansys.
