help needed on verilog PLI
neo_chip
Member level 1
INDIA
verilog pli examples
I need to transfer a value stored in a reg in verilog file to a variable in c file.
I figured out to use acc_fetch_value() (access routine). It seems that this routine would require 3 arguments as inputs.
Can anyone explain on this routine. An example would be more helpful.
Thanks,
Neo
aji_vlsi
Advanced Member level 2
Bangalore, India
pli verilog
Thanks,
Neo
Use Google code search:
https://www.google.com/codesearch?q=acc_fetch_value&hl=en&btnG=Search+Code
And also refer to www.sutherland-hdl.com, his PLI book examples can be downloaded and can be very useful for this sort of stuff.
HTH
Ajeetha, CVC
www.noveldv.com
    neo_chip
xuanzhu
Member level 3
shanghai
verilog pli reg
why not use dpi to finish it. It is very easy for dpi to achieve it.
write a verilog task and export it with returning the reg value, then call the c protetype of the verilog task and transfer the return value to the c program. You can find corresponding detailed information in systemverilog 3.1 specification
