Help me write a code for NCO in Verilog
rajsrikanth
Full Member level 2
Hyderabad
can any one help me to write code for NCO (numerical control oscillator in verilog.
if anyone have the code pls can u send me.
thanx
echo47
Advanced Member level 5
USA
NCO
An NCO can be quite simple: a delta-phase constant repeatedly added to an accumulator. It generates a sawtooth output value, and requires only a few lines of code.
module top (clk, out);
  input             clk;
  output reg [31:0] out = 0;  // assumes Verilog 2001
  always @ (posedge clk)
    out <= out + 170000 * 64'h100000000 / 50000000;  // 170 kHz output, 50 MHz clock
endmodule
Do you need anything fancier than that?
If you need a sinewave output, then you can feed the sawtooth into a sine lookup table.
Plenty of NCO/DDS info available on the web, such as this page:
https://www.hit.bme.hu/~papay/sci/DDS/start.htm
rajsrikanth
Full Member level 2
Hyderabad
Re: NCO
thanx for ur reply.
and i want something in this to be clear. in the above what is the 64bit data.
actually my need is . iam taking samples from ADC and i get modulated data from that and i need to Multiply this NCO output to the ADC output . so in this case how i have to write the code.
echo47
USA
NCO
The value 64'h100000000 equals 2^32, where 32 is the accumulator width, which I chose arbitrarily. I made the value 64 bits wide simply to avoid overflow during the multiplication.
I think you meant to say "i need to Multiply this NCO output by the ADC output". If that's correct, then it sounds like you intend to use the NCO as a local oscillator feeding into a mixer. If that's true, then you probably don't want to use my example until you have converted its sawtooth output into a sinewave. Check your synthesis software libraries for a sinewave table generator, or create your own module.
Depending on your overall system architecture and your synthesis software capabilities, you may be able to simply use Verilog's * multiply operator to mix the NCO and ADC outputs.
rajsrikanth
Full Member level 2
Hyderabad
Re: NCO
in nco how do u take the frequency, and can u tell me how to design frequency syntehsizer,
i have to track the frequency that is obtained from adc. (this is part of a demodulation technique)
rajsrikanth
Full Member level 2
Hyderabad
Re: NCO
track means. carrier tracking. as the signal i obtained is a modulated one so i have to remove the carrier then process actual signal
no confusion mine is a basic demodulation technique. i want to do the demodulation.
