aquif1990
Newbie level 3
I have a 3.8 volt 11 ampere battery. I built a dc booster circuit, which boosts 3.8 volts to 5 volts. I want to charge my android mobile having 2 ampere battery. As i connect my mobile for charging it shows charging for a few seconds then the charging stops. What could be the possible reasons for that.
without load the voltage is 5.06 volts and after applying a load of 5 volt 1 watt the ampere measured in series with the load is 91.555 milli amps.
I uploaded image of my circuit while simulating it.
