echo47
Advanced Member level 6
Here's a simple DDS module (in Verilog) that I wrote long ago. It uses the full width of the Xilinx Block RAM, so you get 18-bit sine and cosine outputs. I directly instantiated and initialized the Block RAM simply because I didn't want to clutter my project with a separate initialization file, or with a "case" statement 1024 lines long. If you are wondering how I generated those initialization values, I used MATLAB.
This DDS module runs about 320 MHz in a Virtex-4. I have a fancier version with a pipelined accumulator that reaches 500 MHz. The Xilinx DDS v5.0 core runs about 340 MHz. You should check the performance of your overall design before handing it off to the next student. You don't want to give him a design that's impossible to implement.
By the way, I don't think you can realistically reach 500 MHz, because that's the maximum frequency of a Virtex-4 Block RAM before considering clock jitter.
I'll look into your filter question maybe a little later today.
module dds (clk, freq, cos, sin);
parameter pbits = 32; // phase accumulator bits
input clk;
input [pbits-1:0] freq; // (1 << pbits) * fout / fclk
reg [pbits-1:0] phase = 0;
reg [9:0] addrcos = 10'h100, addrsin = 0;
output signed [17:0] cos, sin; // quadrature sinewave
always @ (posedge clk) begin
phase <= phase + freq;
addrcos <= phase[pbits-1:pbits-10] + 10'h100;
addrsin <= phase[pbits-1:pbits-10];
end
// Tabulated sinewave ROM, 1024 points, 18 bits
RAMB16_S18_S18 ROMsin (.CLKA(clk), .CLKB(clk), .DIA(16'd0), .DIPA(2'd0), .ADDRA(addrcos),
.ENA(1'b1), .WEA(1'b0), .DOA(cos[17:2]), .DOPA(cos[1:0]), .DIB(16'd0), .DIPB(2'd0),
.ADDRB(addrsin), .ENB(1'b1), .WEB(1'b0), .DOB(sin[17:2]), .DOPB(sin[1:0]));
defparam ROMsin.INIT_00 =256'h0BC30AFB0A33096A08A207D907100647057F04B603ED0324025B019200C90000;
defparam ROMsin.INIT_01 =256'h1833176D16A815E2151B1455138E12C81201113A10720FAB0EE30E1B0D530C8B;
defparam ROMsin.INIT_02 =256'h246723A622E522232161209F1FDC1F1A1E561D931CCF1C0B1B471A8219BD18F8;
defparam ROMsin.INIT_03 =256'h30412F872ECC2E112D552C992BDC2B1F2A6129A328E52826276726A825E82528;
defparam ROMsin.INIT_04 =256'h3BA53AF23A40398C38D93824376F36BA3604354D349633DE3326326E31B530FB;
defparam ROMsin.INIT_05 =256'h467545CD4524447A43D04325427A41CE412140733FC53F173E683DB83D073C56;
defparam ROMsin.INIT_06 =256'h50974FFB4F5E4EBF4E204D814CE04C3F4B9D4AFB4A5849B4490F486947C3471C;
defparam ROMsin.INIT_07 =256'h59F3596458D4584257B0571D568A55F5556054C95432539B5302526951CE5133;
defparam ROMsin.INIT_08 =256'h627161F0616F60EC60685FE35F5D5ED75E4F5DC75D3E5CB45C285B9D5B105A82;
defparam ROMsin.INIT_09 =256'h69FD698C691968A6683267BC674666CF665765DD656364E8646C63EF637162F1;
defparam ROMsin.INIT_0A =256'h708370226FC16F5E6EFB6E966E306DC96D626CF96C8F6C246BB76B4A6ADC6A6D;
defparam ROMsin.INIT_0B =256'h75F475A57555750474B2745F740B73B5735F730772AE725571FA719E714070E2;
defparam ROMsin.INIT_0C =256'h7A417A0579C8798A794A790978C77884784077FA77B3776C772376D9768D7641;
defparam ROMsin.INIT_0D =256'h7D627D397D0F7CE37CB77C897C5A7C297BF87BC57B917B5C7B267AEF7AB67A7C;
defparam ROMsin.INIT_0E =256'h7F4D7F387F217F097EF07ED57EBA7E9D7E7F7E5F7E3F7E1D7DFA7DD67DB07D8A;
defparam ROMsin.INIT_0F =256'h7FFF7FFD7FFA7FF67FF07FE97FE17FD87FCD7FC27FB57FA77F977F877F757F62;
defparam ROMsin.INIT_10 =256'h7F757F877F977FA77FB57FC27FCD7FD87FE17FE97FF07FF67FFA7FFD7FFF7FFF;
defparam ROMsin.INIT_11 =256'h7DB07DD67DFA7E1D7E3F7E5F7E7F7E9D7EBA7ED57EF07F097F217F387F4D7F62;
defparam ROMsin.INIT_12 =256'h7AB67AEF7B267B5C7B917BC57BF87C297C5A7C897CB77CE37D0F7D397D627D8A;
defparam ROMsin.INIT_13 =256'h768D76D97723776C77B377FA7840788478C77909794A798A79C87A057A417A7C;
defparam ROMsin.INIT_14 =256'h7140719E71FA725572AE7307735F73B5740B745F74B27504755575A575F47641;
defparam ROMsin.INIT_15 =256'h6ADC6B4A6BB76C246C8F6CF96D626DC96E306E966EFB6F5E6FC17022708370E2;
defparam ROMsin.INIT_16 =256'h637163EF646C64E8656365DD665766CF674667BC683268A66919698C69FD6A6D;
defparam ROMsin.INIT_17 =256'h5B105B9D5C285CB45D3E5DC75E4F5ED75F5D5FE3606860EC616F61F0627162F1;
defparam ROMsin.INIT_18 =256'h51CE52695302539B543254C9556055F5568A571D57B0584258D4596459F35A82;
defparam ROMsin.INIT_19 =256'h47C34869490F49B44A584AFB4B9D4C3F4CE04D814E204EBF4F5E4FFB50975133;
defparam ROMsin.INIT_1A =256'h3D073DB83E683F173FC54073412141CE427A432543D0447A452445CD4675471C;
defparam ROMsin.INIT_1B =256'h31B5326E332633DE3496354D360436BA376F382438D9398C3A403AF23BA53C56;
defparam ROMsin.INIT_1C =256'h25E826A82767282628E529A32A612B1F2BDC2C992D552E112ECC2F87304130FB;
defparam ROMsin.INIT_1D =256'h19BD1A821B471C0B1CCF1D931E561F1A1FDC209F2161222322E523A624672528;
defparam ROMsin.INIT_1E =256'h0D530E1B0EE30FAB1072113A120112C8138E1455151B15E216A8176D183318F8;
defparam ROMsin.INIT_1F =256'h00C90192025B032403ED04B6057F0647071007D908A2096A0A330AFB0BC30C8B;
defparam ROMsin.INIT_20 =256'hF43CF504F5CDF695F75EF826F8EFF9B8FA81FB4AFC12FCDBFDA4FE6EFF370000;
defparam ROMsin.INIT_21 =256'hE7CCE892E958EA1EEAE4EBAAEC71ED38EDFFEEC6EF8DF055F11CF1E4F2ACF374;
defparam ROMsin.INIT_22 =256'hDB98DC59DD1ADDDCDE9EDF60E023E0E6E1A9E26CE330E3F4E4B8E57DE642E707;
defparam ROMsin.INIT_23 =256'hCFBED078D133D1EFD2AAD367D423D4E1D59ED65CD71AD7D9D898D958DA17DAD8;
defparam ROMsin.INIT_24 =256'hC45BC50DC5C0C673C727C7DBC890C946C9FCCAB2CB69CC21CCD9CD91CE4ACF04;
defparam ROMsin.INIT_25 =256'hB98ABA33BADBBB85BC2FBCDABD85BE32BEDEBF8CC03AC0E8C198C248C2F8C3A9;
defparam ROMsin.INIT_26 =256'hAF68B004B0A2B140B1DFB27EB31FB3C0B462B504B5A8B64CB6F0B796B83CB8E3;
defparam ROMsin.INIT_27 =256'hA60CA69BA72CA7BDA84FA8E2A976AA0AAAA0AB36ABCDAC65ACFDAD97AE31AECC;
defparam ROMsin.INIT_28 =256'h9D8E9E0F9E919F149F97A01CA0A2A128A1B0A238A2C1A34CA3D7A463A4F0A57D;
defparam ROMsin.INIT_29 =256'h9602967496E6975997CD984398B9993099A99A229A9C9B179B939C119C8F9D0E;
defparam ROMsin.INIT_2A =256'h8F7C8FDD903E90A19104916991CF9236929E9307937193DC944894B595239592;
defparam ROMsin.INIT_2B =256'h8A0C8A5A8AAA8AFB8B4D8BA08BF58C4A8CA08CF88D518DAB8E068E628EBF8F1D;
defparam ROMsin.INIT_2C =256'h85BE85FA8637867686B586F68738877B87C08805884C889488DC8927897289BE;
defparam ROMsin.INIT_2D =256'h829D82C682F1831C8349837783A683D68407843A846E84A384D9851085498583;
defparam ROMsin.INIT_2E =256'h80B280C880DE80F68110812A81468163818181A081C181E282058229824F8275;
defparam ROMsin.INIT_2F =256'h800080028005800A800F8016801E80278032803E804A805980688079808B809E;
defparam ROMsin.INIT_30 =256'h808B807980688059804A803E80328027801E8016800F800A8005800280008000;
defparam ROMsin.INIT_31 =256'h824F8229820581E281C181A0818181638146812A811080F680DE80C880B2809E;
defparam ROMsin.INIT_32 =256'h8549851084D984A3846E843A840783D683A683778349831C82F182C6829D8275;
defparam ROMsin.INIT_33 =256'h8972892788DC8894884C880587C0877B873886F686B58676863785FA85BE8583;
defparam ROMsin.INIT_34 =256'h8EBF8E628E068DAB8D518CF88CA08C4A8BF58BA08B4D8AFB8AAA8A5A8A0C89BE;
defparam ROMsin.INIT_35 =256'h952394B5944893DC93719307929E923691CF9169910490A1903E8FDD8F7C8F1D;
defparam ROMsin.INIT_36 =256'h9C8F9C119B939B179A9C9A2299A9993098B9984397CD975996E6967496029592;
defparam ROMsin.INIT_37 =256'hA4F0A463A3D7A34CA2C1A238A1B0A128A0A2A01C9F979F149E919E0F9D8E9D0E;
defparam ROMsin.INIT_38 =256'hAE31AD97ACFDAC65ABCDAB36AAA0AA0AA976A8E2A84FA7BDA72CA69BA60CA57D;
defparam ROMsin.INIT_39 =256'hB83CB796B6F0B64CB5A8B504B462B3C0B31FB27EB1DFB140B0A2B004AF68AECC;
defparam ROMsin.INIT_3A =256'hC2F8C248C198C0E8C03ABF8CBEDEBE32BD85BCDABC2FBB85BADBBA33B98AB8E3;
defparam ROMsin.INIT_3B =256'hCE4ACD91CCD9CC21CB69CAB2C9FCC946C890C7DBC727C673C5C0C50DC45BC3A9;
defparam ROMsin.INIT_3C =256'hDA17D958D898D7D9D71AD65CD59ED4E1D423D367D2AAD1EFD133D078CFBECF04;
defparam ROMsin.INIT_3D =256'hE642E57DE4B8E3F4E330E26CE1A9E0E6E023DF60DE9EDDDCDD1ADC59DB98DAD8;
defparam ROMsin.INIT_3E =256'hF2ACF1E4F11CF055EF8DEEC6EDFFED38EC71EBAAEAE4EA1EE958E892E7CCE707;
defparam ROMsin.INIT_3F =256'hFF37FE6EFDA4FCDBFC12FB4AFA81F9B8F8EFF826F75EF695F5CDF504F43CF374;
defparam ROMsin.INITP_00=256'hD3F23C4FD3DFD07B47A47D0E33282BD7D444B784A6DCDA6F70EC08BFE21B0540;
defparam ROMsin.INITP_01=256'h5469C480C530315D52037F9BF8692C4E1AA36C0E776F00FA4E793943F06DE4C1;
defparam ROMsin.INITP_02=256'h0C6DE43F05B1B6C6BC03E776C0E72A92C4E1A4BF9BF70215D530314C084DA457;
defparam ROMsin.INITP_03=256'h0543922FF880EC37E69CDE684B78445F5FA0A332C1F46B47B41FDF1FC4F23F1D;
defparam ROMsin.INITP_04=256'h715214C5717570D9CDACD7061128297D7CCC9D8CAE747AE5D064089562390FC0;
defparam ROMsin.INITP_05=256'hFCEB4C804F1013F7F201D5B958EB24C63AA1E406DDE5005AC6DB1BC150E76C43;
defparam ROMsin.INITP_06=256'h04E76C150F939E4E94016DDE406D2AB24C63AC95B95D023F7F1013C408C7ACFD;
defparam ROMsin.INITP_07=256'h0FC1B2255880641D6EB476E8C9D8CCF5F5A0A112435CE9CD9C3575354C521537;
endmodule
