GND and VCC pins for max232 in eagle
Rohith_elec
Full Member level 4
How can i make it visible the VCC and GND pin in max232 in eagle , i made it visible by invoke and connected to GND and VCC of supply but it is not visible in board layout
You mean the pins are visible of course, but you can't see the wires? Maybe the board and schematic are out of sync? You could run the ERC from the schematic view.
I think the problem is that you haven't made any connections to the power and ground pins (other than supply symbols) so there is nothing to show a net to.
Keith
various problems are coming when going from sch to brd,
like the Rx Tx connection from uC in sch not showing in brd,
The VCC GND connection is anyhow solved with the help of u people thanks,
someone can check the sch file ?
View attachment untitled.zip
Your Tx/Rx problems are because the wire from the MAX232 goes to a connector but misses the pin. For example, pin 26 of the PIC goes to connector J6 correctly but the connection from the MAZ232 doesn't reach the same point - it stops short.
Your schematic looks a mess - try sticking to orthogonal wires rather than any angle.
Also, run the ERC - there are a lot of other errors in the schematic.
Keith.
  • untitledx.zip
