frequency divider (430Mhz to 10Mhz)
navyashree
Newbie level 1
what would the verilog code to be change a 430Mhz clock to 10Mhz with a reset input
In general - you should use a PLL for such a division ratio . Instead of trying to divide it with logic.
Count from 0 to 42, then start with 0 again...
Klaus
This is true, especially when you want to drive clocked gates with the 10MHz.
Klaus
Usual way for a PLL would be a dual modulus prescaler such as divide by 10/11 used with a fixed divide by four. That would provide division ratios from 40 to 44.
A VCO on the output would then remove the jitter.
But this would have to be be a constantly running frequency divider, not a resettable static counter which is a very different thing.
Relax Guys,
This is another homework type of Q, where the OP wants the Verilog code!
Let her figure out the code, it is not difficult.
