Floorplan-memory placement..
Nantha
Member level 1
Member level 1
India
Hi all,
Right now i'm doing floorplanning.. Is it possible to rotate macro - 90 degree? How to conform this with LEF.?
regards.
Nantha
Ask your fab. They might impose the rule that poly orientation needs to be uniform for the late technology.
You can also read your LEF file and look for the line "SYMMETRY". If this has the entry "R90" then you can rotate the object.
@phoenixpavan: I'm using SOCE...
@lostinxlation: I think they must be noted in library... i wanna know the way how to find this details in lef.... ;)
@richtbiscuits: Ya, it's right. i've already seen that, It has R90. If R90 means we can rotate only 90degree or MX90, R180,270.....????
Thanks a lot for replies.... ;)
Nantha
Ni Nantha,
As richtbiscuits stated, inside LEF file you'll see SYMETRY statement. Here are what they mean;
SYMMETRY X ; #Can flip about the X axis
SYMMETRY X ; #Can flip about the Y axis
SYMETRY R90 ; #Can rotate 90 degrees
BR,
Gokhan
