opened design vision tool and read Verilog file(ISCAS89 benchmark circuit).
The following script was run inorder to compile
read_verilog dff.v
read_verilog s5378.v
link
check_design
uniquify
set verilogout_no_tri true
set_fix_multiple_port_nets -all -buffer_constants
compile
change_name -hier -rule verilog
write -format verilog -hier -out 2006.06.vg
It gives the warnings as shown in error message.
Warning: In design 's5378', a pin on submodule 'dff_172' is connected to logic 1 or logic 0. (LINT-32) Pin 'd' is connected to logic 1.
Warning: In design 's5378', output port 'po_2935' is connected directly to 'logic 1'. (LINT-52)
Warning: In design 's5378', output port 'po_2636' is connected directly to 'logic 1'. (LINT-52)
Warning: In design 's5378', output port 'po_2634' is connected directly to 'logic 1'. (LINT-52)
For some other circuits I get warnings such as "Some nets doesn't have loads (LINT-1)" and "dff have same net as input and output (LINT-33)". LINT-33 is possible but my orginial design is not like this.
I have no idea why design compiler does such crazy modifications? I would really appreciate it if some body can help me with this?
SG
[/b]
