DDR2 interfacing Virtex-5 with MIG 3.6
aminpix
I am trying to connect virtex-5 to DDR2. It is my first time doing this. I know the hardware doesn't have any problem. I compile the code (with no error) and program the FPGA, but phy_init_done never goes high !
This code is only reset the RAM and wait till phy_init_done goes high (which never goes high). My input clock is 100MHz
Anybody can help me about it.
I would appreciate if anybody has any sample DDR2 to Virtex (MIG-3.6) code in ISE and share with me.
Here is my code:
HTML:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_unsigned.all;
use IEEE.NUMERIC_STD.ALL;
library UNISIM;
use UNISIM.VComponents.all;
entity Main_unit is
    Port ( CLK_100M_P			: in  STD_LOGIC;
           CLK_100M_N			: in  STD_LOGIC;
			  LED_01					: out STD_LOGIC;
			  LED_02					: out STD_LOGIC;
			  LED_03					: out STD_LOGIC;
			  LED_04					: out STD_LOGIC;
			  -----DDR2 Interface
				ddr2_dq               : inout  std_logic_vector(63 downto 0);
				ddr2_a                : out   std_logic_vector(13 downto 0);
				ddr2_ba               : out   std_logic_vector(2 downto 0);
				ddr2_ras_n            : out   std_logic;
				ddr2_cas_n            : out   std_logic;
				ddr2_we_n             : out   std_logic;
				ddr2_cs_n             : out   std_logic_vector(0 downto 0);
				ddr2_odt              : out   std_logic_vector(0 downto 0);
				ddr2_cke              : out   std_logic_vector(0 downto 0);
				ddr2_dqs              : inout  std_logic_vector(7 downto 0);
				ddr2_dqs_n            : inout  std_logic_vector(7 downto 0);
				ddr2_ck               : out   std_logic_vector(1 downto 0);
				ddr2_ck_n             : out   std_logic_vector(1 downto 0)
end Main_unit;
architecture Behavioral of Main_unit is
	COMPONENT DCMCLK
	PORT(
		CLKIN_IN : IN std_logic;
		CLK0_OUT : OUT std_logic;
		CLK2X_OUT : OUT std_logic;
		CLK90_OUT : OUT std_logic;
		LOCKED_OUT : OUT std_logic
	END COMPONENT;
component DDR2RAM
    port (
   sys_rst_n             : in    std_logic;
   phy_init_done         : out   std_logic;
   locked                : in    std_logic;
   rst0_tb               : out   std_logic;
   clk0                  : in    std_logic;
   clk0_tb               : out   std_logic;
   clk90                 : in    std_logic;
   clkdiv0               : in    std_logic;
   clk200                : in    std_logic;
   app_wdf_afull         : out   std_logic;
   app_af_afull          : out   std_logic;
   rd_data_valid         : out   std_logic;
   app_wdf_wren          : in    std_logic;
   app_af_wren           : in    std_logic;
   app_af_addr           : in    std_logic_vector(30 downto 0);
   app_af_cmd            : in    std_logic_vector(2 downto 0);
   rd_data_fifo_out      : out   std_logic_vector(127 downto 0);
   app_wdf_data          : in    std_logic_vector(127 downto 0);
end component;
	signal	CLK_100M			:	STD_LOGIC := '0' ;
	signal	sys_rst_n		:	STD_LOGIC := '0' ;
	signal	phy_init_done	:	STD_LOGIC := '0' ;
	signal	locked			:	STD_LOGIC := '0' ;
	signal	rst0_tb			:	STD_LOGIC := '0' ;
	signal	clk0				:	STD_LOGIC := '0' ;
	signal	clk0_tb			:	STD_LOGIC := '0' ;
	signal	clk90				:	STD_LOGIC := '0' ;
	signal	clkdiv0			:	STD_LOGIC := '0' ;
	signal	clk200			:	STD_LOGIC := '0' ;
	signal	app_wdf_afull	:	STD_LOGIC := '0' ;
	signal	app_af_afull	:	STD_LOGIC := '0' ;
	signal	rd_data_valid	:	STD_LOGIC := '0' ;
	signal	app_wdf_wren	:	STD_LOGIC := '0' ;
	signal	app_af_wren		:	STD_LOGIC := '0' ;
	signal	app_af_addr		:	STD_LOGIC_VECTOR(30 downto 0) := (others => '0') ;
	signal	app_af_cmd		:	STD_LOGIC_VECTOR(2 downto 0) := (others => '0') ;
	signal	rd_data_fifo_out			:	STD_LOGIC_VECTOR(127 downto 0) := (others => '0') ;
	signal	app_wdf_data	:	STD_LOGIC_VECTOR(127 downto 0) := (others => '0');
	type t_SM_Main is (s_Idle, s_ddr2_init_00, s_00, s_01, s_02, s_03, s_03n5, s_04, s_04n5, s_05, s_06, s_07, s_08, s_09, s_10);
	signal r_SM_Main : t_SM_Main := s_Idle;
	signal	tmp_CNTR			:	STD_LOGIC_VECTOR(40 downto 0);
begin
IBUFGDS_inst : IBUFGDS
                         generic map (
											DIFF_TERM => FALSE, -- Differential Termination
                                 IBUF_LOW_PWR => TRUE,
                                 IOSTANDARD => "DEFAULT"
                        port map (
                                 O  => CLK_100M, -- clock buffer output
											I  => CLK_100M_P,       -- diff_p clock buffer input
											IB => CLK_100M_N      -- diff_n clock buffer input
  u_DDR2RAM : DDR2RAM
    port map (
   ddr2_dq                    => ddr2_dq,
   ddr2_a                     => ddr2_a,
   ddr2_ba                    => ddr2_ba,
   ddr2_ras_n                 => ddr2_ras_n,
   ddr2_cas_n                 => ddr2_cas_n,
   ddr2_we_n                  => ddr2_we_n,
   ddr2_cs_n                  => ddr2_cs_n,
   ddr2_odt                   => ddr2_odt,
   ddr2_cke                   => ddr2_cke,
   sys_rst_n                  => sys_rst_n,
   phy_init_done              => phy_init_done,
   locked                     => locked,
   rst0_tb                    => rst0_tb,
   clk0                       => clk0,
   clk0_tb                    => clk0_tb,
   clk90                      => clk90,
   clkdiv0                    => clkdiv0,
   clk200                     => clk200,
   app_wdf_afull              => app_wdf_afull,
   app_af_afull               => app_af_afull,
   rd_data_valid              => rd_data_valid,
   app_wdf_wren               => app_wdf_wren,
   app_af_wren                => app_af_wren,
   app_af_addr                => app_af_addr,
   app_af_cmd                 => app_af_cmd,
   rd_data_fifo_out           => rd_data_fifo_out,
   app_wdf_data               => app_wdf_data,
   ddr2_dqs                   => ddr2_dqs,
   ddr2_dqs_n                 => ddr2_dqs_n,
   ddr2_ck                    => ddr2_ck,
   ddr2_ck_n                  => ddr2_ck_n
	Inst_DCMCLK: DCMCLK PORT MAP(
		CLKIN_IN => CLK_100M,
		CLK0_OUT => clk0,
		CLK2X_OUT => clk200,
		CLK90_OUT => clk90,
		LOCKED_OUT => locked
LED_01 <= '0' ;
LED_02 <= locked ;
LED_04 <= phy_init_done ;
process(clk200)
begin
	if (rising_edge(CLK_100M)) then
		case r_SM_Main is
			when s_Idle =>
				LED_03 <= '1' ;
				sys_rst_n <= '0' ;
				if tmp_CNTR(30)= '0' then
					tmp_CNTR <= tmp_CNTR + "0000000000001" ;
				elsif tmp_CNTR(30)= '1' then
					tmp_CNTR <= (others => '0') ;
					r_SM_Main <= s_ddr2_init_00 ;
				else
				end if ;
			when s_ddr2_init_00 =>
				sys_rst_n <= '1' ;
				LED_03 <= '0' ;
			when others =>
		end case;
	end if;
end process;
end Behavioral;
There are several possible issues.
1.) You are running the DRAM at a rate that won't lock the DLLs while using a core that commands the DRAM to enable the DLLs. (Delay Locked Loops)
2.) You expect SSTL on the V5 to be sane and not use power needlessly and haven't cooled the devices properly.
3.) You have reset issues base on active-high vs active-low differences.
4.) The input data is non-zero during calibration.
5.) You can't actually use the design because you have incorrect termination regulators that can't sink current because you assumes any regulator would work.
You can chipscope the design and even look at the source code. It looks like you have a small design. I'd start there if the above doesn't seem relevant.
Your process code is poorly written. You are using the 200 MHz in the sensitivity list but are looking at the rising edge of th 100MHz.
Your FSM doesnt specify the destination state in all branches of the if statement. That is bad coding style IMO, you should explicitly define all state transitions.
Did you look at the example design that the mig tool generates?
