Data not appearing in waveform window
athuluri_mounika
Newbie level 3
Iam using Nios II Eclipse and their i have written the two data inputs required for my simulation and exported to modelsim.
But in the waveform window i was not able to see the data, but surprisingly it is visible on terminal window. The result is also appearing correctly in terminal window.
What might be the issue...is it related stng to installation or whatelse...? Please help me in sorting out this issue...i have a deadline to perform this.
Thanks in advance.....!!!!
Its not really clear what you are talking about. Can you post screenshots of the problem? Have you added the signals explicitly to the wave window before starting the simulation?
Yeah, I have added the signals into my window and started simulation...
As shown in the screenshot in the terminal window i have the results appeared as #123402 ,#11001011...and the added output.
But the same data iam not able to see at the waveforms window and instead im getting some garbage value...
how do you know the values on the console are the signals on the wave window?
how have you made the values appear on the console?
Here, initially i designed a SOC using QSYS system integrator and exported to Nios II Eclipse. Their i have written a C code and now wanted to simulate my SOC using Modelsim.
The values printed in the console are because i have kept them in PRINTF in c code and since the soc is designed it is possible to recognise the signals where my data should be located...
You are not getting garbage values, you are most likely looking in the wrong place for the data transfers in your simulation. Usually these kinds of simulations will have many 100's of uS between the printf output and the original transfer of data. The times I've done these kinds of simulations I just start at time 0ps and start looking for transitions of the memory reads until I find the data I expect.
