thanhtri_pc
Junior Member level 2
Hi all,
I want to design a comparator which can compare two input at verry low-voltage, For example, I want to compare Vi+ = 20mV with Vi- = 30mV. I just used CMOS two-states comparator structure, but I realized that it can compare only if 450mV <= Vi+ and Vi- <= 1.7V (with voltage supply are Vdd = 2V, Vss = 0V).
As you know, if the input voltage is out of range, the comparator does not work properly.
In that situation, we must use another architecture.
Could you show me what the architecture I can use and how to design it?
Many thanks,
Tri Vo
Many thanks,
Tri Vo
